bambam7689 Posted February 25, 2015 Report Share Posted February 25, 2015 So I just purchased a leak down tester kit... I'm a little confused on how to do this properly... any one have a how to? Or have a link for one .. I searched forums but can't really seem to find in detail how to do the test and what to look for Quote Link to comment Share on other sites More sharing options...
prosite@live.com Posted February 25, 2015 Report Share Posted February 25, 2015 Pix of tester kit would help ... Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
possum Posted February 25, 2015 Report Share Posted February 25, 2015 I use a compressor with no problems. Quote Link to comment Share on other sites More sharing options...
bambam7689 Posted February 25, 2015 Author Report Share Posted February 25, 2015 That's the tester I bought Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
bambam7689 Posted February 25, 2015 Author Report Share Posted February 25, 2015 Is it best best to do this on a warm engine or cold engine? Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
maxpower49 Posted February 26, 2015 Report Share Posted February 26, 2015 That's a different kind of leak down tester, it only really tests the top end, on four strokes it can help find burnt valves but on a two stroke it is only really a glorified compression tester and I suppose it could find a bad head gasket as well but it runs off of an air compressor and it only fills the cylinder with air not the entire engine. The one that everyone talks about on here fills the whole engine with compressed air from a bike pump and there is a sticky at the top of the technical info section of the forum on how to build one and use it and here is a link to make life easier click this. Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted February 26, 2015 Report Share Posted February 26, 2015 That's the tester I bought Sent from my iPhone using Tapatalk Looks just like the Harbor Fright one that I use. FYI it will also work for leakdown tester on 2smoke. Drawback is you have to remove tank.But Be creative, using PVC caps for intake boots, drill hole slightly smaller than threads on adapter and force thread adapter into cap. Use 3Bond or permatex #2 on threads. Stock bumper end caps or rubber plumbing caps for exhaust. Nice part is double redundancy with regulator. Turn compressor reg down to 10#, back tester all way out and slowly adjust up. Nice part is if you have clip on tire chuck you can add air and spray soapwater at same time First thing to check is your tester. No leaks in connections, PVC caps to boots, Rubber caps on ex, spark plugs. After that it's just gaskets, seals, intake boots. Flex boots to double check them. Dish soap and water, 25/75 to 50/50. Put trans vent end in glass/cup of water to test case seal and right crank seal. IF you get bubbles, pull clutch cover and test right seal. They can leak at the collar/keyway on crank end. 1 Quote Link to comment Share on other sites More sharing options...
prosite@live.com Posted February 26, 2015 Report Share Posted February 26, 2015 This is what you need to build ... http://bansheehq.com/forums/index.php?/topic/110585-leakdown-tester/ Or you can buy one from ebay http://m.ebay.com/itm/131437729886?nav=SEARCH But building your own will cost a fraction ... I built my owns and it works great Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted February 26, 2015 Report Share Posted February 26, 2015 Well, he already has that tester, I told him how to use it Quote Link to comment Share on other sites More sharing options...
