Ok so i have been looking around and reading alot of different posts on this subject and i am aware there isnt a best banshee pipe its all based on your riding type and what mods you have and or plan to put on. So heres what i have, a 2006 100% stock banshee (the only aftermarket part on it currently is a toomey rad) I mostly ride dirt trails/roads i never drag (nor plan to) and have never been to the dunes (i might some day) the only pipes i have experiance with are toomey t5s and t6s and i love them alot but its hard to dish out 700 plus bucks on the t5 kit but if there the best option i will. I dont plan on doing any major mods the only things that i would do are, a coolhead(will mostlikely get), timing plate(have one coming from chariot right now), jet(based on which pipes i get will determin what jets i get), airfilter(leaning towrds K&N), pipes, hi flow water pump and a arms. I think that should give enough info for some recommendations so please let me know what you guys think.
Paul turner mids are nice for trail/rec riding and since you dont drag at all you probably would like there pull.i have a set forsale along with boysen reed valves and new in the package a pro design filter kit minus the filter, i have 2 used k&n's in good condition i could throw in if interested.
I have both the fmf sst pipes and the dmc 916 setup. I ride mostly tight trails and I think the dmc setup is better then the fmf sst. Not by much but it definitely is. Also sounds better. I can't speak for any other setup though.
You would recommend the dmc over the toomeys? Any particular reason
DMC 916 powerband comes on earlier and has as good a top end as the toomeys if not better plus they are probably one of the best sounding pipes Edited by Uf21
