rjdgriff Posted February 28, 2015 Report Share Posted February 28, 2015 Yes why had the crank welded You recon the bearing will quit Anyway it dosnt matter now I'm doing this new motor I'll go with the domes can gave me I told him I run high comp So he gave me 24cc what he recommends and a set off 23cc both off which are getting coated(ceramic); And as for the flamers you could feel em wanting to jump on the hate train you all need each other to feed egos Ha ha You mad bruh? Quote Link to comment Share on other sites More sharing options...
Dirtsurferaust Posted February 28, 2015 Author Report Share Posted February 28, 2015 Why man Run two digital combustion temp guauges on dash don't let the cylinders get more than 5 degrees difference in heat in any part of the carb curcuits run 180 to 205 depending on ground resistance Drilled out the brass float seat a bit to not suck the bowls dry Made the float height as high as practical Interesting that 21 .5 mm float height runs 35 percent less feul in the bowl than 19 mm height By my measurement anyway I don't know if I was lucky or what There was deto before I put guauges on cause needle curcuit was lean on one side 10 degees out at just one part of the revs even when the needles where same height Cleaned all emulsion tubes and everything else couldn't find the problem Ended up just winding the dialajet on one side Fixed it run the best brown coloured plugs with those things seem to like hi vacume small carbs Small 350 low reciphcating tight jetted engine held together Comp was done by accident I had 21 cc but put in 20 by mistake I must admit it did scare me when I saw the numbers but it held Quote Link to comment Share on other sites More sharing options...
bluebanshee98 Posted February 28, 2015 Report Share Posted February 28, 2015 FFFS Quote Link to comment Share on other sites More sharing options...
rjdgriff Posted February 28, 2015 Report Share Posted February 28, 2015 Why man Run two digital combustion temp guauges on dash don't let the cylinders get more than 5 degrees difference in heat in any part of the carb curcuits run 180 to 205 depending on ground resistance Drilled out the brass float seat a bit to not suck the bowls dry Made the float height as high as practical Interesting that 21 .5 mm float height runs 35 percent less feul in the bowl than 19 mm height By my measurement anyway I don't know if I was lucky or what There was deto before I put guauges on cause needle curcuit was lean on one side 10 degees out at just one part of the revs even when the needles where same height Cleaned all emulsion tubes and everything else couldn't find the problem Ended up just winding the dialajet on one side Fixed it run the best brown coloured plugs with those things seem to like hi vacume small carbs Small 350 low reciphcating tight jetted engine held together Comp was done by accident I had 21 cc but put in 20 by mistake I must admit it did scare me when I saw the numbers but it held 1 Quote Link to comment Share on other sites More sharing options...
Dirtsurferaust Posted February 28, 2015 Author Report Share Posted February 28, 2015 Well to those who like riding and chilled about it I say great good to see enjoy the blurred scenery All the attackers you sad lot you deserve each other! King louii you can have your jungle Quote Link to comment Share on other sites More sharing options...
sprinklerman Posted February 28, 2015 Report Share Posted February 28, 2015 Well to those who like riding and chilled about it I say great good to see enjoy the blurred scenery All the attackers you sad lot you deserve each other! King louii you can have your jungle Are you an Abo? Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted February 28, 2015 Report Share Posted February 28, 2015 I personally think it's great that BansheeHQ has made it all the way in to the native tribes over seas. Can't understand a flipping thing he says, but as long as he's mounting a banshee instead of cattle, I can live with it. I just picture a half naked native with lots of face paint and nothing more then some dried leaves covering his Johnson, screaming across the land WFO! Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted February 28, 2015 Report Share Posted February 28, 2015 I personally think it's great that BansheeHQ has made it all the way in to the native tribes over seas. Can't understand a flipping thing he says, but as long as he's mounting a banshee instead of cattle, I can live with it. I just picture a half naked native with lots of face paint and nothing more then some dried leaves covering his Johnson, screaming across the land WFO!Weird. I imagined them riding kangaroos everywhere and toilets flushing backwards. Quote Link to comment Share on other sites More sharing options...
rjdgriff Posted February 28, 2015 Report Share Posted February 28, 2015 Weird. I imagined them riding kangaroos everywhere and toilets flushing backwards. They have toilets? I figured they just took a shit it the Kangaroos pouch.... Quote Link to comment Share on other sites More sharing options...
Nightmare Posted February 28, 2015 Report Share Posted February 28, 2015 They have toilets? I figured they just took a shit it the Kangaroos pouch....LMAO Quote Link to comment Share on other sites More sharing options...
