Wsm cast piston clearence?
josef9177
You will want to use factory clearances for these pistons.  There is no reason to set them up any looser.  However, it is always important to run an engine in AND ALWAYS warm up an engine before reaming it.  See it all the time where a guy fires up and rips, then cold seizes the engine and blames the clearances.  Remember that a new engine will run HOTTER until run in good.  This is due to extra friction of the new piston and bore.  This is why you need to heat cycle the engine.
If memory serves, .0025 right from the book.  Remember also that casted pistons will setup with tighter clearance than forged pistons.  They have a little more density and silica as well as a little more uniform thermal expansion.
Brandon
Mull Engineering
  • Like 1
