banshee compression
Diesel_89
Needing advice, I have a 1996 banshee with stock stroke,stock cylinder bored 60 over,cool head with 21cc domes and .055 squish, 1000ft elevation.I have used two different compression gages and have 175psi in both cylinders.I've been running race fuel but am wanting to get back to pump gas. Everything I've read says I shouldn't have this high of compression with these mods.Any help would be greatly appreciated.
If they were decked your squish would be tighter than .055 , can you cc the domes yourself , I use marvel mystery oil and a big medical syryng, static compression and uccr are diffrent tho , if you can calculate uccr with that dome it would give you better idea . I have ran 175 psi on pump but motor was set up for it with help from mull engineering, I would try giving him a call , maybe give him some measurements and see what he says
