887ru Posted February 13, 2015 Report Share Posted February 13, 2015 I Have a 2002 Banshee .20 Over, 35 mm carbs, Stage IV Cool Head, Dmc 916's, Ect... I Was Riding at 40 mph and the bike just died. I tried restarting with no luck Kick & Roll. It sounds like it's just pushing gas. I Checked Plug and it's wet but no spark.. Changed coil, cdi and Gas. Still No Spark Does anyone have Woodruff key installation instructions? Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted February 13, 2015 Report Share Posted February 13, 2015 Pull off flywheel with correct puller and not a 3 jaw puller. Put it in slot on crank, slide flywheel on 300 times until you finally get it on with out knocking it out. Tighten flywheel Quote Link to comment Share on other sites More sharing options...
sprinklerman Posted February 13, 2015 Report Share Posted February 13, 2015 Also,I like to use lapping compound to mate the flywheel to crank snout before installing key. Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted February 13, 2015 Report Share Posted February 13, 2015 Might as well ohm the stator. Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted February 13, 2015 Report Share Posted February 13, 2015 Also,I like to use lapping compound to mate the flywheel to crank snout before installing key. This ^^^ and checking the stator. Don't drop the flywheel. Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted February 13, 2015 Report Share Posted February 13, 2015 Puller will be reverse threaded as well. Make sure the threads on the puller and flywheel are clean. A dab of oil is nice as well. When it all goes together, set the pick up gap to about .015 thou, you can file the nubs just a touch if they are nasty and uneven. Quote Link to comment Share on other sites More sharing options...
887ru Posted February 13, 2015 Author Report Share Posted February 13, 2015 I will keep you guys updated Quote Link to comment Share on other sites More sharing options...
n2otoofast4u Posted February 13, 2015 Report Share Posted February 13, 2015 Here's what I do. BUY A NEW KEY. take the key and lay it on a flat surface. Give it a good whack with a hammer and center punch low on the "curve" making a good dimple. CAREFULLY tap it into the crank then install flywheel. Key won't fall the fuck out and you can sleep good knowing that the key is where it's supposed to be. Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted February 13, 2015 Report Share Posted February 13, 2015 Here's what I do. BUY A NEW KEY. take the key and lay it on a flat surface. Give it a good whack with a hammer and center punch low on the "curve" making a good dimple. CAREFULLY tap it into the crank then install flywheel. Key won't fall the fuck out and you can sleep good knowing that the key is where it's supposed to be. Have a pic of this dimple. Because I usually just slide the flywheel on and off 300 times before I think I might have it. Quote Link to comment Share on other sites More sharing options...
n2otoofast4u Posted February 13, 2015 Report Share Posted February 13, 2015 Have a pic of this dimple. Because I usually just slide the flywheel on and off 300 times before I think I might have it.I doubt it. I always toss them and start new. But when you center punch them it makes a very slight "raised" spot around the hole. It makes it very easy to lightly tap it in the crank and hold it right where you want it. Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted February 13, 2015 Report Share Posted February 13, 2015 The last OEM key I bought already had a small dimple on it. I had to lightly tap it in the slot and it stayed nicely. Remember the top of the key (flat) should be level with the floor, not parallel to the crank taper. Quote Link to comment Share on other sites More sharing options...
n2otoofast4u Posted February 13, 2015 Report Share Posted February 13, 2015 The last OEM key I bought already had a small dimple on it. I had to lightly tap it in the slot and it stayed nicely. Remember the top of the key (flat) should be level with the floor, not parallel to the crank taper. I'm not sure if they always had that and I'm just dumb and missed it, or wtf the story is there. But the last batch I bought were dimpled right out of the package as well. Quote Link to comment Share on other sites More sharing options...
locogato11283 Posted February 13, 2015 Report Share Posted February 13, 2015 I carry at least 5 keys with me at all times.. All of mine have the dimple. Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted February 13, 2015 Report Share Posted February 13, 2015 ^ what the concrete guy said. Quote Link to comment Share on other sites More sharing options...
