arena314 Posted February 12, 2015 Author Report Share Posted February 12, 2015 I haven't been riding it since then. How do you go about a leak down test? Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted February 12, 2015 Report Share Posted February 12, 2015 Google is your friend. Some say 6lbs for 6 minutes, 7 for 7. I use a Harbor Frieght cyl tester, couple plumbing pieces for the intake & ex. I need to "modify" the pvc cap I use for intake so I don't need to use spark plug hole. In doing the test if it won't hold air you test the tester for leaks, then move on to engine areas. By chance you don't have a boost bottle do you? Quote Link to comment Share on other sites More sharing options...
arena314 Posted February 12, 2015 Author Report Share Posted February 12, 2015 I had one but I took it off because I heard bad things about them but I don't have the original crossover for it so I looked up what I can do and I heard can tips work well to plug the holes so I went out and bought some of them and plugged the crossover holes with them Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted February 12, 2015 Report Share Posted February 12, 2015 Don't know what "can tips" are, I used some pvc caps I glued in with 3Bond. Don't need no stinkin crossover. When you do test, that is one area to check for leaks. Quote Link to comment Share on other sites More sharing options...
arena314 Posted February 12, 2015 Author Report Share Posted February 12, 2015 I meant cane tips* and if that's leaking what damage does it do to the top end and how bad will it make the bike run? Quote Link to comment Share on other sites More sharing options...
wayne_smith97 Posted February 12, 2015 Report Share Posted February 12, 2015 It will burn up the top end Quote Link to comment Share on other sites More sharing options...
arena314 Posted February 12, 2015 Author Report Share Posted February 12, 2015 Would it cause the problem I'm having with my bike? Quote Link to comment Share on other sites More sharing options...
wayne_smith97 Posted February 12, 2015 Report Share Posted February 12, 2015 It very well could Quote Link to comment Share on other sites More sharing options...
arena314 Posted February 12, 2015 Author Report Share Posted February 12, 2015 I think the jetting would be it because it has stock jets in it Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted February 12, 2015 Report Share Posted February 12, 2015 I think the jetting would be it because it has stock jets in it ^^That and if your cane tips are rubber and on the outside of the rubber intake boot, NO WAY that will seal properly. Quote Link to comment Share on other sites More sharing options...
arena314 Posted February 12, 2015 Author Report Share Posted February 12, 2015 Should I try fixing that first? Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted February 12, 2015 Report Share Posted February 12, 2015 Get you some big jets and do a leakdown test and stop riding it before you melt it down. Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted February 12, 2015 Report Share Posted February 12, 2015 X2 hopped. Quote Link to comment Share on other sites More sharing options...
arena314 Posted February 13, 2015 Author Report Share Posted February 13, 2015 So I was thinking a 290 main but not completely sure what to use for my pilot any recommendations with the mods I have? Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted February 13, 2015 Report Share Posted February 13, 2015 FMF recommends a 30 pilot and a 260 main, stock needle in the 3rd clip and air screw 1.5 out. I personally think 280 or 290 would be much closer. http://www.fmfracing.com/RiderSupport/JettingCenter Quote Link to comment Share on other sites More sharing options...
