hondaracing02 Posted February 15, 2015 Author Report Share Posted February 15, 2015 as in on clutch side of motor? Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted February 15, 2015 Report Share Posted February 15, 2015 as in on clutch side of motor? Yes, you will have to have them out to get the new actuator down in anyway. Quote Link to comment Share on other sites More sharing options...
hondaracing02 Posted February 15, 2015 Author Report Share Posted February 15, 2015 okay, and what kind of greese? just regular greese youd put in like a lawn mower parts? just put it around inside needle bearings of the new bearing with finger? thanks! Quote Link to comment Share on other sites More sharing options...
sleeper06 Posted February 15, 2015 Report Share Posted February 15, 2015 Bel- Ray waterproof grease or equivalent Quote Link to comment Share on other sites More sharing options...
hondaracing02 Posted February 15, 2015 Author Report Share Posted February 15, 2015 any waterproof greece work? Quote Link to comment Share on other sites More sharing options...
hondaracing02 Posted February 15, 2015 Author Report Share Posted February 15, 2015 and put on inside and outside of bearing? cuz wont it be a tight fit? Quote Link to comment Share on other sites More sharing options...
hondaracing02 Posted February 15, 2015 Author Report Share Posted February 15, 2015 The local autoparts store has masterforce marine multipurpose waterproof greece. that work? Quote Link to comment Share on other sites More sharing options...
sprinklerman Posted February 15, 2015 Report Share Posted February 15, 2015 The local autoparts store has masterforce marine multipurpose waterproof greece. that work?Grease. Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted February 16, 2015 Report Share Posted February 16, 2015 Yeah, marine grade should do. Just load the bearing from inside. Quote Link to comment Share on other sites More sharing options...
hondaracing02 Posted February 20, 2015 Author Report Share Posted February 20, 2015 So im taking new bearing and loading it up with my finger with marine grade grease, then pressing it into the case rihgt? doesnt matter if excess grease spills down in? Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted February 20, 2015 Report Share Posted February 20, 2015 No problem, end the rod could use some grease anyway. Quote Link to comment Share on other sites More sharing options...
hondaracing02 Posted February 20, 2015 Author Report Share Posted February 20, 2015 Okay great, and is there torque specs id assume for tightening up clutch side components? Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted February 20, 2015 Report Share Posted February 20, 2015 They will be listed in one of the tables in the clymer manual you should have definitely bought or downloaded by now. Quote Link to comment Share on other sites More sharing options...
