Done some research on where I think I need to be want to compare that with your guys suggestions. My carb experience is very limited.
2006 shee
Head Milled .030"
Timing Plate 4*
CPI sb inframes
V4 Reeds
ModQuad Air Filter Adapter
K&N Filter with Outerwear
No Air Box Lid
110 with Klotz Super Techniplate
700-800' Elevation
Thanks,
Brandon
What temps are you jetting for? Is this a reference for the current 20*-30* weather? OR is this a reference for 80* weather?
Haven't got it buttoned up yet to check it. I have a source for the 110 for cheap figure I'd go ahead and run it? Any I'll affects of using it if not needed?
Brandon
Running a motor with to much octane won't hurt it, but performance would be down if the motor truely doesn't need it. If the motor isn't making a lot of compression or isn't using to much timing, the fuel won't all light and burn completely. When you could potentially take that same motor and feed it premium and actually have a better output then it would on race fuel.
  • Like 1
  • 2 weeks later...
Finally finished all my mods and I can't get the bike to start. I have tried running the idle screws in a 1/2 turn at a time till bottoming out got it to try and fire thats it. Has spark brand new fuel everything tight and new plugs. I put 30 pilots 300 mains 4th clip from blunt end of stock needle. Slides are in sync by eye. The garage is 60* I don't know if that would cause any issues? I set the float level and installed new float needles also. Removed all tors stuff including the black box by the fuel tank. As I stated before I'm carb stupid so maybe this is something small I guess I'm looking for a starting point so I can move forward. I flattened out the boss for the idle screw so I don't think that's an issue. Thanks for any ideas or help and sorry for the long post. 1-1 1/2 out on the mixture screw.
Brandon
Choke tube is in place. I just unplugged it all or is there another step I missed? I'll look to see if I find any bare wires or anything of that nature. Getting spark to both cylinders. The ping marks show up in the glass so assume they are in the proper carbs? Thanks for the help guys makes things a little easier for me! I'll update after I search the harness. Keep the ideas rolling.
Brandon
Edited by bsock
