efi
joeytvr
what else would efi do besides easier starts and more mpg and easier tuning
but a good banshee tunes ok and starts fine
really whats the benefit
It makes tuning ANY setup a snap. With live WB 02 readings/data logging, you can see EXACTLY what's going on. Once you tune it, no matter what elevation or temperature, it fires up easy and runs perfect. The bike will idle all day at 14:1 and never load up. Wire in a flex fuel sensor like I did and then you can run E85/methanol or gas at any time and the ecu will switch parameters automatically. Big thing for drag guys is boost suddenly becomes easy to tune (as has been pointed out). You no longer have to deal with finicky blow through setups that only really seem to run good at idle or WFO.
Need more or less fuel somewhere? 30 seconds with a laptop and done. Want more timing until 7500rpm and pull some at 9500rpm? 30 seconds and done. Soooo much easier. My new motor is being built for E85, but with the flex fuel sensor feedback the ecu will pull timing back to where it won't detonate on pump gas. Put e85 in and the beast will wake the fuck up!
