Pancake bearing.
Gus Aranda
  • 1 month later...
I can't believe nobody has attempted to answe this in a months time!
If you're still interested In advice?? Is the clutch installed and bearing stiff? How much free play is in the lever and where is the arrow pointing on the clutch arm? There is an alignment arrow on the cases that should line up with the clutch arm when contact with the rod is made. Adjust the pancake bearing until the two points line up (assuming you're running a stock style 7 plate clutch). After that adjust the clutch cable until you have at least 1/4" free play in the clutch lever.
If the bearing is stiff to turn after these adjustments then something is damaged or installed incorrectly.
-Brandon
