timing question
Also, you mention you are looking at plates and stators. Be very leary of the stator and cast plate combos.
STAY AWAY FROM:
RM
Rick's
Rickey Stator
Electro Sport
Racetech (suit your self folks, mine didn't work and I had to fix the replacement as well)
So what do you mean by stay away from cast stator and plates?
Do not buy a plate that is cast aluminum. Make sure to get a Billit one. They are 20-30 bucks more, however they prevent catastrophes that are known to happen with the cheaper junk powder cast cheapos.
I modded my stock plate. The OEM stators are the best ones. Look online for a working used one. Make sure you seal the stator side engine cover with RTV even though it has a gasket. I've had problems in the past with water getting behind there. May have been the reason why I killed a stator last summer.
