Compression, timing, and race fuel
Tommygunn
Trying to figure out if I'm doing the right thing here. I have 66mm pistons, 19cc domes, cool head, drag ported cylinders, etc. etc. My compression checks out to be 195lbs in each cylinder. My timing has been set to +5 degrees but I'm told to move it to between +7 and +10 degrees.  I'm running straight 100 race fuel because it's easy to get, I can buy it right at the pump 2 miles from home. Is this enough? Or should I be running 110?  Elevation is 500ft
Thanks
