bpomps215 Posted January 4, 2015 Report Share Posted January 4, 2015 I just did a full too end rebuild on my stock 03 banshee, after rebuild started right up and broke it in properly was riding had it idling then it died and hasnt started since, did a compression test and its only at 65 psi both cylinders, i did notice a constant white smoke coming out of exhausts when it was running, please help me i dont kno what else to do Quote Link to comment Share on other sites More sharing options...
Dixie normus Posted January 4, 2015 Report Share Posted January 4, 2015 Check head gasket. White smoke is from water/coolant. Quote Link to comment Share on other sites More sharing options...
bpomps215 Posted January 4, 2015 Author Report Share Posted January 4, 2015 head gasket looks good Quote Link to comment Share on other sites More sharing options...
Surfrjag Posted January 4, 2015 Report Share Posted January 4, 2015 U forget oil or coolant? What do you mean head gasket looks good? U pulled it appart? Quote Link to comment Share on other sites More sharing options...
Dixie normus Posted January 4, 2015 Report Share Posted January 4, 2015 Throw us a bone here so we can help ya Quote Link to comment Share on other sites More sharing options...
bpomps215 Posted January 4, 2015 Author Report Share Posted January 4, 2015 Has oil and coolant, i know i put the head gasket on right, the quad was just idling and it seemed like one cylinder was going on and off then idled high and turned off Quote Link to comment Share on other sites More sharing options...
Dixie normus Posted January 4, 2015 Report Share Posted January 4, 2015 Was this on a fresh bore? Have you pulled the head to inspect gasket and cyls? Quote Link to comment Share on other sites More sharing options...
NYUK Posted January 4, 2015 Report Share Posted January 4, 2015 some ting wong. Quote Link to comment Share on other sites More sharing options...
Surfrjag Posted January 5, 2015 Report Share Posted January 5, 2015 Ho lee fuuk Quote Link to comment Share on other sites More sharing options...
wayne_smith97 Posted January 5, 2015 Report Share Posted January 5, 2015 Wi tu lo Quote Link to comment Share on other sites More sharing options...
registered user Posted January 5, 2015 Report Share Posted January 5, 2015 before you bother taking head off and make big mess with coolant just got to autozone and rent a free cooling system tester Quote Link to comment Share on other sites More sharing options...
bpomps215 Posted January 5, 2015 Author Report Share Posted January 5, 2015 I didnt bore it or anything just took old piston and rings out and put new ones in and replaced all gaskets Quote Link to comment Share on other sites More sharing options...
bpomps215 Posted January 5, 2015 Author Report Share Posted January 5, 2015 Im pulling the head tomorrow Quote Link to comment Share on other sites More sharing options...
Dixie normus Posted January 5, 2015 Report Share Posted January 5, 2015 Did you make sure the ring gaps were on the Pistons correct? Quote Link to comment Share on other sites More sharing options...
bpomps215 Posted January 5, 2015 Author Report Share Posted January 5, 2015 Yes they were at the holding tabs Quote Link to comment Share on other sites More sharing options...
