muggzy Posted December 28, 2014 Report Share Posted December 28, 2014 (edited) Anyone know where I can get a fill neck to weld in? (preferably alum.) I've asked around locally and I get these dumb looks followed by "wow, you'd think that would be easy" but then a shrug followed by idk. I dont want to put the over-sized (desert) tank up front, just don't like the way it looks and thought a container to fit in a six-pack rack would do the trick and look pretty trick. Esp if it was connected to the stock tank or the carbs via a shut-off and check valve. I just need a fuel cap and therefore a neck to mount it on. You see american chopper and other TV shows fabbing that stuff for custom bike tanks but who's making the fill neck for them? They always seem to just appear. Edited December 28, 2014 by muggzy Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted December 28, 2014 Report Share Posted December 28, 2014 I used a 3gal spun aluminum tank off ebay and took a 6-pack rack and cut the bottom rails off the rack and welded on new mounting brackets for the tank onto the 6-pack rack. I use a shutoff valve under the tank, then a filter then it feeds into the back of the front tank. I run my dune bike on methanol and get more mileage out of my two tanks than the stock banshees do on gas with just the front tank.I aldo did the same thing for the tank on my R6 raptor. The factor air box and carbs sit under the front plastics so I moved the tank to the rear just like my dune banshee. Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted December 28, 2014 Report Share Posted December 28, 2014 That came out wrong, I quoted that. Those are a members tanks. Bigred350x. Those are his, I've never had one. Maybe someone here can get in contact with him as he hasn't been on in a while. Quote Link to comment Share on other sites More sharing options...
muggzy Posted December 28, 2014 Author Report Share Posted December 28, 2014 That's the basic idea, but I'm looking to make something low and flat. Rectangular like a brief case, but small enough to fit in the rack and to be unobtrusive. I'll figure out the exact dimensions and capacity once I can find an aluminum filler neck/cap combo. But I'm thinking I could get an extra gallon or two that way. Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted December 28, 2014 Report Share Posted December 28, 2014 Some one made one under the seat not to long ago. Never saw much more of it after the first post. I'll see if I can find it. Quote Link to comment Share on other sites More sharing options...
muggzy Posted December 28, 2014 Author Report Share Posted December 28, 2014 Some one made one under the seat not to long ago. Never saw much more of it after the first post. I'll see if I can find it. thanks Quote Link to comment Share on other sites More sharing options...
Buckwheat Posted December 28, 2014 Report Share Posted December 28, 2014 http://www.rdsaluminum.com/ A company in my hometown. Quote Link to comment Share on other sites More sharing options...
rockenrail Posted December 28, 2014 Report Share Posted December 28, 2014 Check out the chassis shop. Quote Link to comment Share on other sites More sharing options...
rockenrail Posted December 28, 2014 Report Share Posted December 28, 2014 Hmmm link no worky..... Go to Chassisshop.com and search for "cap". You will find quite a few caps with bungs. Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted December 28, 2014 Report Share Posted December 28, 2014 Look at JD's RotoPak. It's a slim bumper/fuel tank and it is removable. Quote Link to comment Share on other sites More sharing options...
Burke Posted December 28, 2014 Report Share Posted December 28, 2014 check with Stellar or Turbo Chassis and maybe they'll tell you where they get theirs for the drag tanks Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted December 28, 2014 Report Share Posted December 28, 2014 Check Jegs or Summit Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted December 28, 2014 Report Share Posted December 28, 2014 http://www.fillernecksupply.com/servlet/StoreFront Quote Link to comment Share on other sites More sharing options...
muggzy Posted December 28, 2014 Author Report Share Posted December 28, 2014 Got it... Like this one a lot: Chassisshop.com http://secure.chassisshop.com/partdetail/C73-755/ Thanks! Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted December 28, 2014 Report Share Posted December 28, 2014 That thing is killer! Quote Link to comment Share on other sites More sharing options...
