03DMshee Posted December 26, 2014 Report Share Posted December 26, 2014 Aw man! Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted December 26, 2014 Report Share Posted December 26, 2014 There is no variety, theres 110mm stock rod length or 115mm "long rod". With the 110mm rod with a 4mm stroke and stock pin height piston you can either use a spacer plate or cut into the dome the 2mm youve added with stroke. With the 115mm "long rod" with a 4mm stroke and the 795 series piston with a 5mm higher pin height you have the same options to make up the 2mm of stroke, spacer plate or cutting deeper into the dome. Then at .080'' (66mm) you go to the 573 series piston and make up less in the dome because its +6mm higher pin height than stock. with either setup, the proper porting and cutting the dome deeper are the better/correct way to go over a spacer plate. What about that 11883(?) piston you guys had made a while back? Are they beginning to sell. Quote Link to comment Share on other sites More sharing options...
Atomic Monkey Posted December 26, 2014 Report Share Posted December 26, 2014 I'm running the 11882 pistons with no issues in a +4, 115 rod, 65mm bore engine. These are the pistons that were made so a person could use the stock head with a thicker base gasket instead of the spacer. So anyway there's that option... and with my build the cylinders are ported to use the stock thickness base gaskets with custom domes. Driveline Performance helped me out a lot with this setup, thanks guys! Quote Link to comment Share on other sites More sharing options...
O/CbansheeRider Posted December 26, 2014 Report Share Posted December 26, 2014 Anybody know how to tighten chain on oem carrier? I cant figure it out. Sent from my iPhone using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
jscharphorn Posted December 26, 2014 Author Report Share Posted December 26, 2014 You need a big hammer, loosing 2 bolts on your front arm and then wack the rear carrier it to break it loose Quote Link to comment Share on other sites More sharing options...
BANSHEE HP Posted December 26, 2014 Report Share Posted December 26, 2014 What about that 11883(?) piston you guys had made a while back? Are they beginning to sell. Those are Rays pistons for all his stock cylinders and 4mm cranks with a 115mm rods he sells. Same as using a 573 series as far as gaskets and cutting into the dome. Quote Link to comment Share on other sites More sharing options...
O/CbansheeRider Posted December 26, 2014 Report Share Posted December 26, 2014 You need a big hammer, loosing 2 bolts on your front arm and then wack the rear carrier it to break it looseIt was a joke. Some of these other guys know what I mean. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
TRR Posted December 26, 2014 Report Share Posted December 26, 2014 When they say drop in crank?? Can it be dropped in from 3 or 4 feet above.? I can't remember. Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted December 26, 2014 Report Share Posted December 26, 2014 Typically 4 ft.. Quote Link to comment Share on other sites More sharing options...
jscharphorn Posted December 26, 2014 Author Report Share Posted December 26, 2014 on a serious note, I just checked the compression on the motor I am going to build and left side is 105 and right is 120 so I know I will not know for sure until I pop the top but is it possible it does not need a bore ? If it needs a bore then I might want to rethink the cylinder deal because the port job will be $400 from redline and if I have to stick money in the cylinders another way also then what would be my best route to take ? Quote Link to comment Share on other sites More sharing options...
registered user Posted December 26, 2014 Report Share Posted December 26, 2014 Now an expert on cranks after the other day couldn't figure out why a piston was made. never said i was a expert, just alot smarter than you, which aint saying much i guess. to have a run of one off pistons or rods made costs money. im not in the business of selling parts so having a batch of 25 units sitting in my garage is a bad idea. besides i dont want to tie up my money on something like that either, again because im not in the parts selling business nor do i ever want to be. got better things to do than peddle parts out of my garage to low ballers like you. oem rods are junk on anything besides a bone stock engine. got one in the garage that looks like a banana. not real impressed with hotrods either. it wouldnt be difficult to design a superior rod but i dont have to because better stronger stuff is alreay out there, your just to stupid to know what parts to use. Quote Link to comment Share on other sites More sharing options...
sprinklerman Posted December 26, 2014 Report Share Posted December 26, 2014 Hmm. I guess the guys running stock cranks and rods on 120+ hp turbo motors must be doing it wrong. .. 1 Quote Link to comment Share on other sites More sharing options...
jscharphorn Posted December 26, 2014 Author Report Share Posted December 26, 2014 Off to a good start on that 15pg bull crap posting I complained about at the beginning. Quote Link to comment Share on other sites More sharing options...
registered user Posted December 26, 2014 Report Share Posted December 26, 2014 zilla fag this is just one of several better options. dont bother asking for details cuz ill tell ya to piss up a rope. got one even superior to this rod but im not gonna show it. no made in taiwan shit here. it just boils down to whether you wanna be a sheep and follow or find a different better way. peace out bro Quote Link to comment Share on other sites More sharing options...
registered user Posted December 26, 2014 Report Share Posted December 26, 2014 Hmm. I guess the guys running stock cranks and rods on 120+ hp turbo motors must be doing it wrong. .. everyones entitled to their choice of parts. who am i to say its the wrong decision. aparently they felt the oem stuff was sufficient for the task. Quote Link to comment Share on other sites More sharing options...
