STRIBZ Posted December 19, 2014 Report Share Posted December 19, 2014 HEy guys need abit of insight on my jetting situation.. Mods: Fmf fattys +4 timing Tors removed No air box twin k+ns Riding st sea level At the moment i have 30pilot 320main needle 3rd clip and on my plugs i have a light blackish ring only going 1/4 around the base ring? Am i lean or am i rich? What should i change next? Any help would be greatly appreciated.. Quote Link to comment Share on other sites More sharing options...
lil Doobie420 Posted December 19, 2014 Report Share Posted December 19, 2014 Sounds a lil rich for not having any porting. 1 Quote Link to comment Share on other sites More sharing options...
STRIBZ Posted December 19, 2014 Author Report Share Posted December 19, 2014 Thats what i thought, but i was under the impression that the oil/fuel ring should go all the way around the base ring of the plug? Quote Link to comment Share on other sites More sharing options...
Sandking Posted December 19, 2014 Report Share Posted December 19, 2014 What temp. If 70s or above should be 290-300 on main. Quote Link to comment Share on other sites More sharing options...
STRIBZ Posted December 19, 2014 Author Report Share Posted December 19, 2014 Im in aus and its 40 degrees celcius Quote Link to comment Share on other sites More sharing options...
Sandking Posted December 19, 2014 Report Share Posted December 19, 2014 320 seems rich try a 300 or 290 Quote Link to comment Share on other sites More sharing options...
todd.thompson.3975 Posted December 26, 2014 Report Share Posted December 26, 2014 (edited) What would you guys say I need to start at for jetting my banshee Mods: Bills pipes Trinity stage 4 intakes 34mm carbs 66mm pistons It's ported but not sure what port job No air box K&n pods Stock head Stock reeds I believe Stock stroke Plan on different pipes but need a ballpark to start with don't wanna blow her up just got done rebuilding topend Not sure on elevation I live in indiana Edited December 26, 2014 by todd.thompson.3975 Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted December 27, 2014 Report Share Posted December 27, 2014 Keihin carbs or mikuni's? Quote Link to comment Share on other sites More sharing options...
todd.thompson.3975 Posted December 27, 2014 Report Share Posted December 27, 2014 Keihin Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted December 27, 2014 Report Share Posted December 27, 2014 Hmm. The porting is really gonna dictate how much fuel that'll eat. If it isn't to aggressive I'd start about 50 pilot, needle middle clip, 150 on the main. Work your way down. Probably end up with a 48 pilot, needle one clip from the top, 145-148ish main. The idle on those arbs is different. Here is the easiest way. Get both chokes turned all the way in and seated. Now use paint pen or white out to mark the knobs so you can keep track of their location. Back them both out 7 1/2 turns. If the pilot is on that should get you in the ball park. Quote Link to comment Share on other sites More sharing options...
todd.thompson.3975 Posted December 27, 2014 Report Share Posted December 27, 2014 It idles good now and runs good I I can't remember the jets that are in it now it runs like a raped ape but I have the air screws out 3 turns and that seems a bit much haven't don't a chop test yet but I know my jets are bigger than what you said so I know I am running rich if my air screw is out 3 full turns right? And by choke screw you mean the black plastic screw with a spring on it right? Sorry for the hassle and like I said don't know what port but this banshee is pretty mean compared to others that I have rode I just got it and rebuilt it so only know of them things that are done to it I will do a chop test this coming up week when I am off work and get my jet sizes again and get back with you but thanks for the quick reply and also with how the weather changes up here (hot to cold or cold to hot) would I have to rejet for the seasons? Quote Link to comment Share on other sites More sharing options...
RadarRacing Posted December 27, 2014 Report Share Posted December 27, 2014 If you have 320 mainjets then you do NOT have keihins. You have mikunis. Also to any and all that read this thread. YOU DO NOT JET CARBS BY HOW FREAKIN OILY THE PLUGS LOOK. I am not bashing you but there are way too many noobs that think thats how you set jetting correctly. "If it runs like a raped ape" and idles perfect , just ride it and enjoy. Your tuning thread is done. Quote Link to comment Share on other sites More sharing options...
todd.thompson.3975 Posted December 28, 2014 Report Share Posted December 28, 2014 I never said I had 320 main jets and I do have keihins Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted December 28, 2014 Report Share Posted December 28, 2014 He was referring to a post above yours. Quote Link to comment Share on other sites More sharing options...
todd.thompson.3975 Posted December 28, 2014 Report Share Posted December 28, 2014 Oh OK well thank for the input trickcarbine but I just ordered a bunch new parts for shee so hopefully when I get her put back together again I can restart with trying to jet again lmao Quote Link to comment Share on other sites More sharing options...
