arielblazed94 Posted December 10, 2014 Report Posted December 10, 2014 alright so i will be rebuilding my banshee in January and i need tips and tricks what could help me make the process of taking the bike apart alot easier and alot more organized for myself.. i will be changing my bearings and repainting my frame and just cleaning up the whole bike to give it a fresh start Quote
sleeper06 Posted December 10, 2014 Report Posted December 10, 2014 Zip lock bags, sharpie, impact gun,clymer manual, and take pictures. Buy a bolt kit from site sponsor. On occasion axle bearing and axle need to be pressed out or air chiseled out 1 Quote
arielblazed94 Posted December 10, 2014 Author Report Posted December 10, 2014 i had zip lock bags and sharpie in mind i also have the clymer manual i also have all the bolts i need i dont have an impact gun though and what is air chiseled ? Quote
Big Mike NY Posted December 10, 2014 Report Posted December 10, 2014 Air chisel = stobburn bolts that don't want to come out, specifically swing arm pivot bolt.. Quote
Green95LX Posted December 10, 2014 Report Posted December 10, 2014 (edited) Just did this, honestly once you start in it's not bad at all. One piece of advice i can give is to leave as much of the assemblies as you can together and put bolts back into parts where you can also. Also if a bolt seems stuck, don't keep trying and risk stripping the head. Get the impact gun after it, i had several allen head bolts stuck, zipped right out with an impact. Edited December 10, 2014 by Green95LX 2 Quote
sheerider11 Posted December 10, 2014 Report Posted December 10, 2014 Note pad and pen. Write shit down. What you need, broken stuff, ideas, anything that comes to mind in a split second. Nothing like getting it together and then being like "damn, I forgot to do that right after I said it." Get a metric tap/die set. I made it a habit on bikes I work on to go through all the holes/bolts. Make sure there good and clean. Especially after powder coat. Quote
lastnline75 Posted December 10, 2014 Report Posted December 10, 2014 Blue Loctite by the 5 gallon buckets... Quote
arielblazed94 Posted December 11, 2014 Author Report Posted December 11, 2014 i had the worst experience removing the steering stem bearing spent like 5 hours hammering it and with a blow torch (during the summer), i think i can get it back together in less then a week Quote
