Pwk alky info
Would yall say i need to run a pump if im running pwk with billet bowls oversized an a dual pingel on a small motor,plse need feed back on whats best,dnt need blown pistons
If everything is modified right & the tune-up is sound. You don't need the pump.
We started with a pump on our 1/4 mile 443cc quad & weaned our self off the pump when we had the experience. 1/4 mile & the hillshooting put the greatest demands for fuel delivery.
When we 1st started running asphalt we ran 35 PWKs & they had custom needles. We switched to race gas & to 39/41 PWKs with a DGH needle.
When we built the 643cc DMX we converted our 41s to Alky we use the DGH needle, dumps drilled .120, 55 pilots & power jet discharge tubes drilled. Cant's remember the size somewhere around .100. This set-up was only tested on asphalt at the airport for around 400', but has been tested at 300' sand.
The bowls are the Boss ones & are the largest I know of.
What size PWKs?
