cwdaniel Posted December 4, 2014 Report Share Posted December 4, 2014 What I’m working with: 2002 Banshee, mostly stock other than no TORS and air box replaced with K&N pods. FMF pipes. “Boost tube” intake crossover. Runs just fine in the dunes for my son. I’m not the rider, just the pit crew. The problem: For the second time now we have lost an intake filter and sucked sand and ruined the rings. Also for the 2nd time I have found cracks in the connection for the crossover tube on the carb boots. Looking for some recommendations on upgrades/improvements for more durable/reliable pieces. Is this “boost tube” doing anything significant over the stock crossover tube? I suspect that the added mass of the part vibrating is cracking the boots. Or possibly the un supported weight of the carbs without the air box. Quote Link to comment Share on other sites More sharing options...
hp2000 Posted December 4, 2014 Report Share Posted December 4, 2014 Boost tube doesn't do anything but look ugly and bulky. I've never lost a K&N clamp on and I ride dunes also. Make sure all surfaces are clean and clamps are good also do you have the correct size filters? Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
03DMshee Posted December 4, 2014 Report Share Posted December 4, 2014 Go to a factory crossover tube...can prolly find a few in the for sale threads...all that boost bottle is doing is exactly what you said its is...cracking your boots causing a lean condition... As far as pods...like HP said...make sure they are right size and mating surfaces are clean... Quote Link to comment Share on other sites More sharing options...
cwdaniel Posted December 4, 2014 Author Report Share Posted December 4, 2014 K&N RU-0210 they fit fine. And we do our best to keep them tight and clean. Though the rider isn't very diligent. I've found you can't over tighten them or it will squeeze them off. Not much shoulder on the carb. I'm thinking a more narrow OEM type clamp would be better. Quote Link to comment Share on other sites More sharing options...
BUILDER Posted December 4, 2014 Report Share Posted December 4, 2014 Loose the boost bottle like said above. You need to run a stock cross over tube and just make sure your filters are on their nice and straight and you should have no issues with them falling off unless you are running a extra wide clamp or something like that. I have regular hose clamps on all 3 of my bikes and I have never had one fall off. Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted December 4, 2014 Report Share Posted December 4, 2014 Loose the boost bottle like said above. You need to run a stock cross over tube and just make sure your filters are on their nice and straight and you should have no issues with them falling off unless you are running a extra wide clamp or something like that. I have regular hose clamps on all 3 of my bikes and I have never had one fall off.This. I actually have one size up from my carbs and the still clamp on really well. Do you have genuine K&N pods? They clamp better and aren't as prone to ripping. Quote Link to comment Share on other sites More sharing options...
cwdaniel Posted December 4, 2014 Author Report Share Posted December 4, 2014 Genuine as they come in a K&N box. Unless there are imposters out there. Interesting we seem to be unique suffering from this. Is there any carb changes through the years that would have a more or less suitable clamp surface? Even the previous owner had the same problem. Quote Link to comment Share on other sites More sharing options...
BUILDER Posted December 4, 2014 Report Share Posted December 4, 2014 Dont get me wrong I have seen this happen to other peoples bikes I have just not had it happen to me. No the carbs are all the same over the years unless someone has put different ones on it but I know you say they are stock. I would just make sure you are not over tightening them is my only guess. Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted December 4, 2014 Report Share Posted December 4, 2014 X 10 on the boost bottle needing to go to the trash. Get a stock cross over tube. Here is a bracket Arlen at LED produces. I've seen many fellas make something similar. Maybe give it a try. http://ink361.com/app/users/ig-1272118076/ledperformance/photos/ig-756581775541540649_1272118076 1 Quote Link to comment Share on other sites More sharing options...
oldskool Posted December 4, 2014 Report Share Posted December 4, 2014 If your intakes have cracks from said boost bottle, they need to be replaced. There are some intakes out there with no crossover. Quote Link to comment Share on other sites More sharing options...
cwdaniel Posted December 5, 2014 Author Report Share Posted December 5, 2014 X 10 on the boost bottle needing to go to the trash. Get a stock cross over tube. Here is a bracket Arlen at LED produces. I've seen many fellas make something similar. Maybe give it a try. http://ink361.com/app/users/ig-1272118076/ledperformance/photos/ig-756581775541540649_1272118076 That's a slick setup. I like the concept. Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted December 5, 2014 Report Share Posted December 5, 2014 If your intakes have cracks from said boost bottle, they need to be replaced. There are some intakes out there with no crossover. This ^^^ too. Or, Take boot to hardware, get pvc cap that fits, install with 3bond and clamps, that's what I did Quote Link to comment Share on other sites More sharing options...
ohSIXshee Posted December 7, 2014 Report Share Posted December 7, 2014 Ive had a filter come off in the dunes. Forunatly it didnt mess anything up. But what i found was the filter pod i had was about 6 years old and the rubber has hardened vs a new filter. Bought new filters havent had a problem. Next i will try out the toomey 2 into 1 filter. Quote Link to comment Share on other sites More sharing options...
registered user Posted December 7, 2014 Report Share Posted December 7, 2014 What I’m working with: 2002 Banshee, mostly stock this is just me but i would put the airbox back on. use some pantyhose or whatever over the top of the box if you dont use the lid or atleast a filter skin over the filter. ill bet money youve gained almost nothing with them pod filters on that particular engine 1 Quote Link to comment Share on other sites More sharing options...
cwdaniel Posted December 15, 2014 Author Report Share Posted December 15, 2014 this is just me but i would put the airbox back on. use some pantyhose or whatever over the top of the box if you dont use the lid or atleast a filter skin over the filter. ill bet money youve gained almost nothing with them pod filters on that particular engine My thoughts exactly. So this is what I came up with: Got a smoking deal on a pair of stock air boxes. One with a K&N and outer wear and one stock. Cut the bottom out, some booty fab brackets to support where the original frame tabs gone. I think this will do fine. Quote Link to comment Share on other sites More sharing options...
