I was inspired by (domestic bitch's) build+I went from there. It's coming along little by slow,I'm learning as i go.
Right on. Aside from the light brackets and a tab on the front tubes, I almost thought it wast the one domestic & I did. We spent quite a bit of time on that one. It was pretty fun.
Whoever did that frame used all the stock frame parts and modified them. The front rails were pied and bent in together right after the stock shock mounts. You can see the bumper mount holes also. And all the Aarm tabs are all stock. So he used all the stock lower rails and upper Aarm rails.And by the location of steering bearing, bet it has crazy bump steer.
Edited by possum
I got a message back from Jim, his frame is actually in the works as we speak. It sounds like his design is solid. The new frame he's having built kid being built from 100% mandrel bent chromoly and it uses a stock yfz subframe that's been modded for the banshee seat and plastic.
Zilla, he told me he had 3D CAD models and the prints I had were generic renderings but he didn't come off of anything but these two pictures comparing the two frames. He said the fabricator he's using wanted the 3D CAD models, prints, and both frames present in order to build the hybrid frame.
I brought up tabbing a yfzr frame for banshee plastic and modifying the motor mounts. He said the YFZ cradle geometry was symmetrical and the chassis balance from left to right would be off.
http://s292.photobucket.com/user/james_taylor20/media/Mobile%20Uploads/image_zpseub4ftwc.jpg.html%5D%5BIMG%5Dhttp://i292.photobucket.com/albums/mm29/james_taylor20/Mobile%20Uploads/image_zpseub4ftwc.jpg%5B/IMG%5D%5B/URL%5D
http://s292.photobucket.com/user/james_taylor20/media/Mobile%20Uploads/image_zps4fwbdwln.jpg.html%5D%5BIMG%5Dhttp://i292.photobucket.com/albums/mm29/james_taylor20/Mobile%20Uploads/image_zps4fwbdwln.jpg%5B/IMG%5D%5B/URL%5D
Edited by MOTTO-MAN YFZ
This is a billet crank with a special extra deep weld. It isn't billet nor welded. Jim's word can not be trusted.
received_909039829217603_zpsaeqez6wt.jpe
After being caught in his lie, he makes up bullshit reasons to him giving the guy a deal.
received_909057889215797_zpswiahirah.jpe
That's pretty bush league.
Sent from my SM-G900V using Tapatalk
Here is how much of his bullshit you should believe. ..
ZERO
