xt45 Posted November 22, 2003 Report Share Posted November 22, 2003 If I buy a brand new banshee today, and I will use it everyday for 2 hours, [1] how many months and/or years will go by before it gets problems [2] and what sort of problems will it be Quote Link to comment Share on other sites More sharing options...
NYUK Posted November 22, 2003 Report Share Posted November 22, 2003 if you take care of it, buy a clymer manual,do regular maintenance, remove the tors.remove stock air filter+replace it with an aftermarket,jet it correctly, you will have very few problems.you will need a bore job after a while ,new pistons and rings.and most important you will need new underwear. always wear clean underwear, my mother told me. Quote Link to comment Share on other sites More sharing options...
2004LEBanshee Posted November 22, 2003 Report Share Posted November 22, 2003 a good point that is often over looked. Quote Link to comment Share on other sites More sharing options...
streetshee Posted November 22, 2003 Report Share Posted November 22, 2003 i ride about 600-1000 km each month,have now 11700 street km ,no problems,fully synthetic castrol2 stroke oil,gear box oil every 4-600km,sparkplugs 3-4000km,clean filter monthly,well actually i lied,had a problem with carbs stickin but hasnt happened since i hose clamped the choke tube tight,and axle locknut commin loose(bit of locktite seems to work) but maybe now shees a little overdue for a set of rings,end of the month i sort her out.who sez shees are unreliabe eh!? Quote Link to comment Share on other sites More sharing options...
bignasty1 Posted November 22, 2003 Report Share Posted November 22, 2003 just take care of it and dont beat the shit out of her and it will be all gravy ya know. my friend rides every day(just about) and is on the same top end for the last 3 yrs and has only lost 4-5lbs of compression in each cylinder and his only other mechanical prob was he had a float stick and that was fixed easily so just take care of your bike and it will last. Quote Link to comment Share on other sites More sharing options...
SCOTT PRESSLEY Posted November 23, 2003 Report Share Posted November 23, 2003 Like the others said, Take care of the shee and the shee will take care of you. Quote Link to comment Share on other sites More sharing options...
xt45 Posted November 23, 2003 Author Report Share Posted November 23, 2003 Thanks guys, I was told if you drive the banshee in the 6th gear for 1 hour on the asphalt, it will break down. Banshee must only be used off-road, is this true. Quote Link to comment Share on other sites More sharing options...
Toomey Banshee Posted November 23, 2003 Report Share Posted November 23, 2003 Hey NYUK, clean underwear? If you (or me for that matter) get in a "prediciment" (sp?) dont you think you're gonna shit yourself anyway? Quote Link to comment Share on other sites More sharing options...
streetshee Posted November 23, 2003 Report Share Posted November 23, 2003 its not true at all that sheel breakdown after an hour in top gear,and also totaly wrong that should only ride off road,depends on yer set up,if u got off road tires then shees better off road,lower her,add some 225/40/10 and 165/70/10 wheels n tires and shees a killer on the street. see ya. Quote Link to comment Share on other sites More sharing options...
xt45 Posted November 23, 2003 Author Report Share Posted November 23, 2003 Like the others said, Take care of the shee and the shee will take care of you. I will make sure to ride her everyday for 1 hour. Quote Link to comment Share on other sites More sharing options...
SCOTT PRESSLEY Posted November 23, 2003 Report Share Posted November 23, 2003 That's right they love attention Quote Link to comment Share on other sites More sharing options...
