Timing plate?
onebadhemi
CC them. Screw in spark plug, hold dome upside down. Place piece of plexi glass with small hole drilled over mating surface. Load liquid syringe full to CC mark. Fill dome with syringe. Note new measurement and subtract it from the full amount. The difference will be the dome's CC
what if your measuring an engine that the piston comes above deck like a 7mm?
Tricked got it. I was referring to a 7mm stroker stock cylinder. But i guess any positive deck motor would suffice. which part of the piston to you use, the center or the edge when measuring to cut the plate?
Edge like squish. Gotta get creative to factor the volume of the crown if it's in your math.
