MessyJesse69 Posted November 18, 2014 Report Share Posted November 18, 2014 i ran me shee without oil for about 2 miles DOH! i plan on replacing gaskets and all bearings if nothing else looks like it needs attention. But i figure while im in the bottom end i want to make sure ill never have to split the cases again while i own my shee. What do you guys recommend without breaking the bank? im mainly looking to never have to split the cases again but is there anything that has got a good bang for the buck while im into it? all input is welcome Quote Link to comment Share on other sites More sharing options...
MessyJesse69 Posted November 18, 2014 Author Report Share Posted November 18, 2014 previous owner claims its bored .40 over i guess im going to find out. ill probably do rings as well maybe pistons. anything else that would compliment the bike? im saving up for pipes fucking retard before me put a 2:1 system on it. from what ive read it really robs it of the top end Quote Link to comment Share on other sites More sharing options...
rjdgriff Posted November 18, 2014 Report Share Posted November 18, 2014 well no oil means your rod bearings could of gotten some heat.. id look into getting the crank inspected... if its the original crank throwing in a new one can never hurt... esp if you plan on putting new bearings on it... already half the price of a new one when doing so... 2-1 pipes can be solid for trails but does rob peak ponies... IMO... if you ran with no oil, got no clue what the previous owner did.... send the cyls out to get honed or bored if needed and throw in some new pistons... don't fuck around with a old crank esp if you want it to last a long time after this... go new.. don't patch shit with "rings" ^^ This. Get a good hotrod trued and welded crank, wisco pistons and while it's all apart, take a look at your tranny, shift forks, etc and also check out your water pump Quote Link to comment Share on other sites More sharing options...
BUILDER Posted November 18, 2014 Report Share Posted November 18, 2014 Ya what ^^^^^^^^^^^^^^ ask? Quote Link to comment Share on other sites More sharing options...
possum Posted November 18, 2014 Report Share Posted November 18, 2014 im assuming trans, cause it wouldnt make it 2 miles with no mix! Quote Link to comment Share on other sites More sharing options...
MessyJesse69 Posted November 19, 2014 Author Report Share Posted November 19, 2014 Lol no tranny oil and the previous owner claims it was a 30 hour old rebuild from crank up. It makes a weird ass screeching/ grinding noise when I start it. It almost sounds like a dieing cat. I can't afford to have the head honed unless it's relatively cheap. I'm working at Wendy's and I'm 17 I'm lucky enough to find a guy to split the cases for a case of natty light lol thank god for friends Quote Link to comment Share on other sites More sharing options...
MessyJesse69 Posted November 19, 2014 Author Report Share Posted November 19, 2014 www.youtube.com/watch?v=a_r2bIdOn88 Here's the noise while the bIkes off. Quote Link to comment Share on other sites More sharing options...
MessyJesse69 Posted November 19, 2014 Author Report Share Posted November 19, 2014 If anyone hasn't a clue I'll post a video of it with the bike on but I have all the fluids drained currently Quote Link to comment Share on other sites More sharing options...
MessyJesse69 Posted November 19, 2014 Author Report Share Posted November 19, 2014 With the bike on its basically the same noise but constant and much louder Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted November 19, 2014 Report Share Posted November 19, 2014 If anyone hasn't a clue I'll post a video of it with the bike on but I have all the fluids drained currently Like I said in your other post, It's a bad bearing...in your transmission 1 Quote Link to comment Share on other sites More sharing options...
possum Posted November 19, 2014 Report Share Posted November 19, 2014 either bad bearing. but im leaning towards flywheel, key, loose stator etc... pull the flywheel already! Quote Link to comment Share on other sites More sharing options...
MessyJesse69 Posted November 19, 2014 Author Report Share Posted November 19, 2014 I know but I'm just trying to gather as much input as possible before k start this tear down Quote Link to comment Share on other sites More sharing options...
MessyJesse69 Posted November 19, 2014 Author Report Share Posted November 19, 2014 I will, I pulled flywheel cover it didn't seem loose I couldn't wiggle it with my hand. How would I check to see if it's the flywheel key Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted November 19, 2014 Report Share Posted November 19, 2014 I'm assuming in your video that it's making that horrible noise while you are rotating the sprocket by the chain that it is in neutral and that the flywheel is NOT turning? Quote Link to comment Share on other sites More sharing options...
MessyJesse69 Posted November 19, 2014 Author Report Share Posted November 19, 2014 I didn't have the cover off while I made that video. Yes it was in nuetral. I did however start the bike with the flywheel cover off and nothing looked like it was out of whack the sound seemed to becomming from inside the cases in the rear of the motor. But what would you do first if it was your bike before splitting the cases? Quote Link to comment Share on other sites More sharing options...
