satts Posted November 16, 2014 Report Share Posted November 16, 2014 Hi everyone,quick question ,when I shift bike into first gear ,if I don't keep a fews revs up it's wanting to stall,any ideas? Clutch need adjusting at the pressure plate or something else?help is appreciated Quote Link to comment Share on other sites More sharing options...
Factory350 Posted November 16, 2014 Report Share Posted November 16, 2014 Has it sat for a while? sometimes the clutch plates will stick together when it's sat or the oil isn't warm. Once you ride I bit, it should free up. Quote Link to comment Share on other sites More sharing options...
Bennett131 Posted November 16, 2014 Report Share Posted November 16, 2014 Your basket could have some grooves in it. Quote Link to comment Share on other sites More sharing options...
Guest Rucking Fetarded Posted November 19, 2014 Report Share Posted November 19, 2014 Does the adjuster underneath the left carb line up with the arrow? Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted November 20, 2014 Report Share Posted November 20, 2014 It should, or be relatively close Quote Link to comment Share on other sites More sharing options...
vrx46 Posted November 28, 2014 Report Share Posted November 28, 2014 You in a cold environment? You run it a lot? Let it warm up? Rev that shit up and keep it warm then see what happens Quote Link to comment Share on other sites More sharing options...
satts Posted November 29, 2014 Author Report Share Posted November 29, 2014 Everything is new and aligned but havnt noticed if it happens when it's warm ,will report back Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted November 29, 2014 Report Share Posted November 29, 2014 working the clutch lever during warm-up may help Quote Link to comment Share on other sites More sharing options...
