I have a 1988 j arm banshee was completely stock with a .10 over bore. Just yesterday I put a complete turbine core2 exhaust system on. Changed the jets running 290 main and 27.5 pilot now the bike is running very lean. The original main jet was a 190 don't remember the pilot. But before the mods the bike was running prefect. Need some suggestions by the way the weather here is in the mid 30's
Mid 30s?! Fahrenheit or Celsius?
If °f then that's way cold. Prob need to up jetting across the board. Pilot needle and main. Also, park the fucking thing. To cold to ride.
If °C then you should be close. I'd look into a leak.
Do a leak down regardless. For intake boots and gaskets that old I wouldn't be surprised if there all dry rotted and cracked.
Also check if your choke tube is in place. May have knocked it out.
  • Like 1
