2000 Banshee Stuff
mcaf29
I was going to list everything i have individually but it'll be easier to just list it here. If you want pics of anything let me know and I'll post em or e-mail em. Make reasonable offers.
Set of K&N clamp-ons (used twice, too wet here) w/ new in package outerwears
The coolant bracket is available if needed.
Rear shock (red)
Front hubs w/ brandy new pivot works bearings (on ebay right now)
Cometic top end gasket kit
Stock clutch basket w/ bushings (you'd have to rerivet it)
Stock upper a-arms
stock lower right a-arm
stock lower left a-arm has bad ball joint if you can replace
Set of brand new tierod ends and tierods
timing plate (comes with working stator but not healthy looking)
Stock flywheel
Balanced Flywheel that needs new rivets.
Stock swingarm
Stock carbs with assortment of jets
Stock shift drum (no forks)
Stock coil
I looking to get $100 for it. Its in really good shape. I can grab a pic if interested. It always felt good to me, I was just at K&K one day getting my new front shocks and arms and decide to get an axis rear shock and LSR swingarm while I was there. Now I need the cash to hook the motor up. Banshee = broke.
I also forgot to list:
Stock intakes
Stock reeds and cages
Reed spacers
Forgot about these too:
stock carrier w/ brand new bearings and seals (the bearings are in my freezer ready to install)
stock sprocket hub
stock brake hub
stock tightening nuts
I also have a stock axle that is mushroomed on the left side. If anyone has machining skills or wants it as a core I'm selling for super cheap. Say $25 plus shipping. Just need to get it out of here so when the Navy moves me I don't have excess weight. I can get a pic of the damage.
