yes, new motor....new reeds....
What about a small exhaust leak at the pipe where it attaches to the motor...there are orings in there...I don't think I used any silicone like my other bikes...
Do you think its wise to put money into a crank im gonna get ride of in a few months?
Deff gonna do the full c clip pto mod also have a pancake bearing and shifter star coming.
I looked over the tranny and clutch everything looks great im hopeing new seals will keep it clean and keep the air leaks away I have winderosa seal kit on its way.
Should I remove the pins on the bearings and Loctite them or leave them in and Loctite it and what color Loctite?
Also what kinda case saver is the best
Im thinking it should be running next week depending on the machine shop
Just got the bottom end all together.
The pancake bearing seems a little weird, that the nut only threads on a couple threads when the arrows are aligned on the arm and the cases.
Everything else went together great, do you guys think that all new seals would make it a little tighter to roll over by hand.
Thanks for the helpful info just waiting on the machine shop now.
