finishing my long serval build
RagunCajun
I'm the person who made the thread which is here
http://bansheehq.com/forums/index.php?/topic/171188-pictures-of-cleaned-up-frames/page-5
However, still waiting on people to identify what tabs are what.
I guess ill start tapping off what ill cut off and make sure by posting pictures here before i grind. Ill be back later with pictures...
Ok here we go.
#1 is the OEM silencer location.
http://i240.photobucket.com/albums/ff111/raguncajun/DSC01898_zpsx4qolnam.jpg
#2 is stock exhaust pipe(expansion chamber) mounts
http://i240.photobucket.com/albums/ff111/raguncajun/DSC01897_zpsbsotse1v.jpg
I'm not sure what # 3 is. I cant see much from my old picture of my bike when it was last together.
http://i240.photobucket.com/albums/ff111/raguncajun/DSC01900_zpsqdg2hsgf.jpg
Can someone confirm?
Also on pic #1 right where you put "#' there is the tabs on the inside of the frame for the airbox as well. Those can be removed. If your not sure circle it like you did and we can confirm it
http://i240.photobucket.com/albums/ff111/raguncajun/DSC01898-2_zpse1cxeg1a.jpg
Yea the little circle in green is that little tab that sticks out on both sides of the inside of the frame. Remove that. Remove it all the way to the frame. It will be the round tab and the square box that connects to it. Does that make sence? Also the flat bracket 2 of 2 on both sides
