bigweav81 Posted June 7, 2016 Report Share Posted June 7, 2016 I would ignore anyone selling used gaskets for a nickel, or two anyway. Sent from my SM-S820L using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
ClaudeMachining Posted June 8, 2016 Report Share Posted June 8, 2016 My 35 are hard on the thumb too... I think I will look at honda throttle.... Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted June 8, 2016 Report Share Posted June 8, 2016 My 35 are hard on the thumb too... I think I will look at honda throttle....Work great on the 35's. But you DO need to grind the inside. Don't listen to the self proclaimed Honda expert 1 Quote Link to comment Share on other sites More sharing options...
RagunCajun Posted June 8, 2016 Author Report Share Posted June 8, 2016 Perhaps a chariot throttle may be better Clyde. Double the price but it's proven. Or you can machine a light weight version. Quote Link to comment Share on other sites More sharing options...
LaegerEliminator Posted June 8, 2016 Report Share Posted June 8, 2016 My 35 are hard on the thumb too... I think I will look at honda throttle....Have you tried shortening the springs or buying the softer springs that are available? I took about 30% out of mine and have been very happy with that. No issues either. Quote Link to comment Share on other sites More sharing options...
ClaudeMachining Posted June 8, 2016 Report Share Posted June 8, 2016 Have you tried shortening the springs or buying the softer springs that are available? I took about 30% out of mine and have been very happy with that. No issues either. Yeah, I did that on my stock carbs and on some snowmo too. I will do it tomorrow but I think it will be not enough. Envoyé de mon GT-P5113 en utilisant Tapatalk Quote Link to comment Share on other sites More sharing options...
Bennett131 Posted June 8, 2016 Report Share Posted June 8, 2016 Chariot/Cuervo ftw Quote Link to comment Share on other sites More sharing options...
JTmachining Posted June 8, 2016 Report Share Posted June 8, 2016 My 35 are hard on the thumb too... I think I will look at honda throttle....There's carb slide springs that have lighter pressure available from certain builders Quote Link to comment Share on other sites More sharing options...
LaegerEliminator Posted June 8, 2016 Report Share Posted June 8, 2016 There's carb slide springs that have lighter pressure available from certain buildersUm, I did mention this in my post. Quote Link to comment Share on other sites More sharing options...
JTmachining Posted June 8, 2016 Report Share Posted June 8, 2016 Um, I did mention this in my post.Canada is slow so I'm helping him out. U need props? Props lol 3 Quote Link to comment Share on other sites More sharing options...
Scrubby Posted June 9, 2016 Report Share Posted June 9, 2016 you still need a stock thumber? I switched to twist, so its just sitting on the bench. Quote Link to comment Share on other sites More sharing options...
RagunCajun Posted June 9, 2016 Author Report Share Posted June 9, 2016 Yes I do. Quote Link to comment Share on other sites More sharing options...
RagunCajun Posted June 11, 2016 Author Report Share Posted June 11, 2016 Figured I'd ask while at work. Does my chain seem too loose? It's all the way tight in the adjuster. I'm afraid if i take another link out, it will be too tight. http://i240.photobucket.com/albums/ff111/raguncajun/DSC02125_zpshugfjjaa.jpg I plan to go ride after work so I will shorten the chain when I knock off for lunch. Gotta run a whole tank of fuel before I can beat on her. Hopefully that doesn't take long. Quote Link to comment Share on other sites More sharing options...
bluebanshee98 Posted June 11, 2016 Report Share Posted June 11, 2016 Yea looks loose. Are you sure it's adjusted correctly? I make my chains pretty damn tight 1 Quote Link to comment Share on other sites More sharing options...
RagunCajun Posted June 11, 2016 Author Report Share Posted June 11, 2016 It's my first time with a round style carrier but the essential is all the way in the back(which is all the way tight) . I'll put it toward the front and see if I can overlap The chain Quote Link to comment Share on other sites More sharing options...
