detroit08111 Posted October 22, 2014 Report Share Posted October 22, 2014 for me its an issue with the clutch cable it is loose it is not stretched or broke its a new cable, clutch perch screw is all the way out and its still loose. Wen I put it in gear and hold clutch its jumps and shuts off its like the clutch is not engaging Quote Link to comment Share on other sites More sharing options...
Bennett131 Posted October 22, 2014 Report Share Posted October 22, 2014 Should we donate some clues? Quote Link to comment Share on other sites More sharing options...
detroit08111 Posted October 22, 2014 Author Report Share Posted October 22, 2014 you guys are crazy can I get some help here lol Quote Link to comment Share on other sites More sharing options...
sheesfast Posted October 22, 2014 Report Share Posted October 22, 2014 Thought we covered this last nite? Anyone else smell spam cooking? Quote Link to comment Share on other sites More sharing options...
detroit08111 Posted October 22, 2014 Author Report Share Posted October 22, 2014 well I never got the right answer because it didn't work Quote Link to comment Share on other sites More sharing options...
Bennett131 Posted October 22, 2014 Report Share Posted October 22, 2014 All you want is help help help. Quote Link to comment Share on other sites More sharing options...
sheesfast Posted October 22, 2014 Report Share Posted October 22, 2014 You never gave enough details for anyone to truly help you. Now your asking for $$$. Good luck with either. Quote Link to comment Share on other sites More sharing options...
detroit08111 Posted October 22, 2014 Author Report Share Posted October 22, 2014 come on guys your spamming mi tread with nonsense now stop it Quote Link to comment Share on other sites More sharing options...
sheesfast Posted October 22, 2014 Report Share Posted October 22, 2014 I think your throw out or pilot bearing may be bad in the engine. Check it and report back. Measure them for proper clearance and check gear lash also. Quote Link to comment Share on other sites More sharing options...
Bennett131 Posted October 22, 2014 Report Share Posted October 22, 2014 You spammed this whole repairs and mods section with your bullshit...feel free to fug off. Quote Link to comment Share on other sites More sharing options...
detroit08111 Posted October 22, 2014 Author Report Share Posted October 22, 2014 Thanks will do Quote Link to comment Share on other sites More sharing options...
sheesfast Posted October 22, 2014 Report Share Posted October 22, 2014 Once you have the lash of your transaxle intermediate gears let us know. We will factor the variances of the transducer for you if you don't know how. Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted October 22, 2014 Report Share Posted October 22, 2014 for me its an issue with the clutch cable it is loose it is not stretched or broke its a new cable, clutch perch screw is all the way out and its still loose. Wen I put it in gear and hold clutch its jumps and shuts off its like the clutch is not engagingThe wording is a bit backward bu I get what you're saying. When the lever is out the clutch is fully "engaged". With the lever in it is "disengaged". So you're saying it is lurching even with the lever pulled in. This is usually a tell tale sign that the basket or hub have pretty bad grooving. Try the adjustment procedure I posted in your other thread, or let me know I you got my message. Quote Link to comment Share on other sites More sharing options...
