won't idle when cold
tyler73
my 2006 banshee won't idle when its cold more then 3 seconds  but when its warm it idles just fine it also  sounds weird at the beginning of a rev when cold like its falling on its face  and some times it dies when i do that  the only mods on the bike is t-5 pipes and silencers, v-force3 reeds k&n filters with no air box at all  and I'm not sure about what is all done to the carbs besides tors removed
Does it idle when cold if you leave the choke pulled out? Need to look at see what size main and pilot is in the carbs.
when it finally starts up the choke automatically  goes   in by itself
Hold the choke out half way with your hand and see if it stays running. Pretty much sounds like your pilot is just too small. Really need to pull the jets out and see what is in it.
You need to remove the carbs to take the jets out and make sure you only remove one at a time that way you do not swap slides or get anything mixed up between them. You should probably have a 27.5 pilot and somewhere around a 320 main jet in the bike with the mods you listed
