Nightmare Posted October 14, 2014 Report Share Posted October 14, 2014 So are you looking for the later model front setup? Quote Link to comment Share on other sites More sharing options...
sr73087 Posted October 21, 2014 Author Report Share Posted October 21, 2014 I bought this banshee about a month ago as a project. I might end up keeping it, it really depends. It is a 98 and figured it would likely have 98 brakes on it. Quote Link to comment Share on other sites More sharing options...
sr73087 Posted October 30, 2014 Author Report Share Posted October 30, 2014 Looks like the one side has the 87-89 setup but the other side missing a caliper is different. What pictures would you need to know what model it came off of? Quote Link to comment Share on other sites More sharing options...
Atomic Monkey Posted October 30, 2014 Report Share Posted October 30, 2014 I have the calipers and master off of my 97 if you need anything. As far as the YFZ450 brake setup goes, its the later models that got the better master (forget the year they started), otherwise besides the lever and brake switch, the master is the same as the Banshee. Quote Link to comment Share on other sites More sharing options...
sr73087 Posted November 23, 2014 Author Report Share Posted November 23, 2014 Yea it looks like the upper and lower control arms are the same but the spindle on the right side (with brake) is different from the other side. Quote Link to comment Share on other sites More sharing options...
sr73087 Posted July 11, 2017 Author Report Share Posted July 11, 2017 So just getting back to this, I know its been awhile. It looks like the right side is definitely the 87-89 and all together, however the left side is something different. I just want to verify that I just need a spindle. It looks like the hub is the same. The reason I realized this is that I purchased an 87-89 brake caliper with bracket and the spacing is different so the caliper bracket will not bolt up. Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted July 11, 2017 Report Share Posted July 11, 2017 Hubs are different, notice the back of the wheel studs and the recess for the rotor bolts Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted July 11, 2017 Report Share Posted July 11, 2017 rotors are different too, but probably interchange Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted July 11, 2017 Report Share Posted July 11, 2017 rotor bolts must match the hubs Quote Link to comment Share on other sites More sharing options...
sr73087 Posted July 11, 2017 Author Report Share Posted July 11, 2017 So the rotors are interchangeable, but I would need to switch over the bolts based on the hubs? And the knuckle on the left side (side I need a caliper), is off an a-arm? Just to clarify, I have an a-arm upper and lower control arm with a J-arm brake setup? Quote Link to comment Share on other sites More sharing options...
ginger Posted July 11, 2017 Report Share Posted July 11, 2017 it looks like your one side has a a arm spindle, but no caliper, and the other side has a j arm setup. so you are going to want to replace one of your spindles so they are the same setup one each side, either another j arm spindle, and run all the j arm brakes, or another a arm, and 2 calipers for a arm brakes. Quote Link to comment Share on other sites More sharing options...
sr73087 Posted July 11, 2017 Author Report Share Posted July 11, 2017 Ok that is what i thought. Thanks guys. Quote Link to comment Share on other sites More sharing options...
Chukkinsod Posted July 12, 2017 Report Share Posted July 12, 2017 I have a full Front brake set up including master and lever for sale...PM if interested Quote Link to comment Share on other sites More sharing options...
