Shifting problem
So, you tipped the motor to the right side, and the rod slid out, but no ball? Just for info, the rod goes in, then the ball, and then the clutch pusher/ adjuster with the pressure plate. If you have an aftermarket pancake bearing, make sure it goes washer, roller bearing, washer, then the pressure plate. While it's apart, you should check the clutch actuator(that the clutch cable hooks to) for wear.
