trickedcarbine Posted November 2, 2014 Report Share Posted November 2, 2014 Ok ^ but we were talking banshee right? Quote Link to comment Share on other sites More sharing options...
lil Doobie420 Posted November 2, 2014 Report Share Posted November 2, 2014 I usually bench test the carbs with the bowl off to see exactly where its leaking from. Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted November 3, 2014 Report Share Posted November 3, 2014 (edited) No one has mentioned the O-ring on the outside of the float needle seat. Don't waste money on rebuild kit, as they come with stock jets, and if you have any mods at all, the jetting will be wrong. Just get seat, needle, o-ring, maybe gasket. Carb Parts Warehouse or Sudco, Yammy Stealership Unless your choke really bothers you, don't bother replacing, it's 35$ Edited November 3, 2014 by Larry's Shee Quote Link to comment Share on other sites More sharing options...
sr73087 Posted November 23, 2014 Author Report Share Posted November 23, 2014 You can't really see anything in the pictures. The needle has a very very small indentation around it. Its only slightly viable with a light on it, otherwise you can't see any indentation where the needle seats. I know it is very precise but this is literally nothing. I purchased this off someone who bought it from someone else as a project, they knew very little about it, so I am not sure if it is still the stock jetting. How do I check? The other issue is that my carb rebuild kit does not look to have a needle. Pictures below. Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted November 23, 2014 Report Share Posted November 23, 2014 ANY sign of a groove is bad Buying a rebuild kit is stupid Do you only read like every other response in your own thread? Quote Link to comment Share on other sites More sharing options...
sr73087 Posted November 23, 2014 Author Report Share Posted November 23, 2014 Thanks for the help but the last part of your post is unnecessary. Based on everything else I have found on this banshee so far, the rebuild kit seemed like a good idea because I have found many missing bolts screws etc. Plus I figured I would replace other seals and parts while I was in there. Other users suggested to just rebuild it while I was in there as well. Now, does it make sense that this kit does not have a needle? Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted November 23, 2014 Report Share Posted November 23, 2014 Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted November 23, 2014 Report Share Posted November 23, 2014 I purchased this off someone who bought it from someone else as a project, they knew very little about it, so I am not sure if it is still the stock jetting. How do I check? The jets all have numbers stamped on them. I saw in another thread you had Toomey pipes, so it should NOT have stock jetting and the ones in the kit should NOT be used. Even the main needle could be different as Toomey recommends their own. But few people actually use it. Quote Link to comment Share on other sites More sharing options...
sr73087 Posted November 23, 2014 Author Report Share Posted November 23, 2014 (edited) Ok got it. Its inside the seat. Are the numbers just the opening size in the jet? Edited November 23, 2014 by sr73087 Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted November 23, 2014 Report Share Posted November 23, 2014 Ok got it. Its inside the seat. Are the numbers just the opening size in the jet? Yes Quote Link to comment Share on other sites More sharing options...
sr73087 Posted November 24, 2014 Author Report Share Posted November 24, 2014 Replaced the needle and seat. Still leaking. I guess the previous owner messed with the float height? Is their any reason to touch this when jetting? This is the only thing it could be correct if the fuel is spilling out from the overflow? Quote Link to comment Share on other sites More sharing options...
ETR174 Posted November 24, 2014 Report Share Posted November 24, 2014 Yeah float height would be the only problem now. Flip your carb over on a table and get calipers to measure 21mm, put it on the lip that the gasket sits on (without the gasket on) and bend the top of the floats to the caliper measurements. Quote Link to comment Share on other sites More sharing options...
sr73087 Posted November 24, 2014 Author Report Share Posted November 24, 2014 And that is just seating the needle but without compressing the spring correct? Quote Link to comment Share on other sites More sharing options...
ETR174 Posted November 24, 2014 Report Share Posted November 24, 2014 Spring? Quote Link to comment Share on other sites More sharing options...
sr73087 Posted November 24, 2014 Author Report Share Posted November 24, 2014 the top of the needle is spring loaded. It will allow the float to continue down, but does not affect the needle itself. Quote Link to comment Share on other sites More sharing options...
