biglaaa Posted October 4, 2014 Author Report Posted October 4, 2014 When I get a chance to get the bike down to him i def will .. Already spoke with him about that . What is the best oil to use for a banshee ? Quote
trickedcarbine Posted October 4, 2014 Report Posted October 4, 2014 There will be as many opinions as there are brands. As long as it's a quality brand designed for performance two stroke you will be fine. No junk weed eater or equipment oil. Quote
biglaaa Posted October 4, 2014 Author Report Posted October 4, 2014 Thank you man !! Thank you to everyone for the help Quote
Larry's Shee Posted October 4, 2014 Report Posted October 4, 2014 Also jetted Rich since temp here is 65-70 and I'm jetting so I can last the winter , which will drop to 20s for winter New York city Jetting for 65/70* won't be enough for 20* 1 Quote
biglaaa Posted October 4, 2014 Author Report Posted October 4, 2014 Jetting for 65/70* won't be enough for 20* What should I jet for then ? I jetted where she is a little rich considering it's still 60s in NYC .. Quote
trickedcarbine Posted October 5, 2014 Report Posted October 5, 2014 Jetting for 65/70* won't be enough for 20*Sure it will, motor won't need the extra fuel with a hole in each piston. OP, ride it and get it nice and dialed to where you feel comfortable with it. Then once weather starts to change and temp drops, you will need to jet to compensate. Pilot not so much, it'll probably be fine down to 40 ish with air screw adjustments, but every 15-20 degrees colder will need to see a needle and main change. Quote
biglaaa Posted October 5, 2014 Author Report Posted October 5, 2014 How much leaner should I go for the winter ? Quote
Larry's Shee Posted October 5, 2014 Report Posted October 5, 2014 Richer not leaner with cold. From "perfect" jetting about one main size for every 20* colder. Quote
biglaaa Posted October 5, 2014 Author Report Posted October 5, 2014 Gotchya thank you appreciate it !! Quote
trickedcarbine Posted October 5, 2014 Report Posted October 5, 2014 Richer not leaner with cold. From "perfect" jetting about one main size for every 20* colder.Good save Quote
