This is a 4 mil stock cyl. setup for methenol built by DMR (Dave Moore Racing). Fresh top end with blaster pistons.The cylinders are drag ported by DMR for methenol with a ModQuad head with DMR 4 mil domes. V Force 2 reeds with new pedals, 34mm Mikuni Tm Carbs Bored to 36mm with DMR power jets and K&T over sized bowls. CPI both out left side drag pipes with DMR carbon fiber silencers. A new 8 plate clutch with a Hinson basket, ModQuad lockup and straight cut gears. The tranny is a WCR 2-5 neutral down dune able override. It has a Dyna ignition, drag radiator and drag tank. This bike has consistently been the fastest 4 mil stock cyl at Sand Mtn. NV being clocked at 75 MPH with a 208 lbs. rider.
The frame is completely custom and light weight. +2 forward a arms with upper aluminum heims and steel lowers and chrome drag spindles. +10 ladder bar swingarm, solid motor mounts. DMR chrome 1 of a kind sub frame and grab bar. ModQuad drag axle. Marvin Shaw comps on the front and a hillshooter on the rear. Complete custom rear brake setup. Custom steering stem and bars. Front Direct Drive 10x2 5/8 spindle mounts with smooth triple buffs and rear 8x7 wheels with custom staggered Skat Trak 12 paddle triple buff 8 hauler 4 glider combos.
I'm sure I have forgot a lot more. This bike weighs 260 lbs. ready to ride. This is a very clean, fast reliabe quad. I just don't have time to use it anymore. My loss your gain! $6000.00 OBO. Pink slip in hand.
Call or text
Link to Craigslist https://chico.craigslist.org/snw/4688694040.html
