Shift lever problem.
91coupemike
There's lots of mods in there that are worth doing. Just a matter of how much money you are willing to spend. Billet clutch basket, pancake bearing, shift shaft mod, shift star mod, ball bearing detent roller (Commonly called Shift Pro. Do not use the Shift Pro spring. Mull sells just the bearing and bolt), steel kicker idler gear bushing, billet water pump gear, billet water pump impeller. Measure the thickness of your clutch fibers. If they are in spec, run them.
