draggins10 Posted September 25, 2014 Report Posted September 25, 2014 Just switched my stock carbs for mikuni 28mm flat slides. As suggested I tried out 300 main jets, 30 pilot jets and 2nd clip on the needle. The best I got it running was with the idle screws 2 turns out and the air/fuel screws fully turned in, and it was still breaking up in the low to mid range but it seemed to pull fine up top. Where do you guys think I should go from here with jetting? Quote
draggins10 Posted September 25, 2014 Author Report Posted September 25, 2014 (edited) Mods are fmf pipes, +4timing, 4 mil crank with spacer plate,boysen reeds, uni filter w/o lid and these 28mm mikuni carbs Edited September 25, 2014 by draggins10 Quote
sleeper06 Posted September 28, 2014 Report Posted September 28, 2014 How does is idle? Could be a sync issue ,usually low to mid breakup is the pilot to needle transition try needle adjustments go richer one clip at at time? The fact that your air screws are all the way in tells me you need a bigger pilot? Are you sure there are no air leaks Quote
draggins10 Posted September 28, 2014 Author Report Posted September 28, 2014 It idles fine. I don't think there is an air leak because it ran fine before I changed the carbs. So to go richer on the needle I move it down one groove right? Quote
