Best Banshee Computer (Speed, Tach, Temp)
ETR174
I havent kept up so i honestly dont know.  Seriously just put a cheap water temp gauge that you can glance at once in a while and get yourself a handheld GPS with a mount.  You can use the GPS for other things besides the bike and actually get some use out of it. You will never use the tach even if it works i promise you.
The back light worked fine on the stator
I don't think the stator messed with the tach
With the speedo the sensor that came with it was fucked so they sent out a replacement which worked but will sometimes read while I'm parked and will drop out while rolling just had no success with it
Have re fitted it and checked everything numerous times with no success
Never mind man sorry for being an asshole. From what it sounds like the Vapor doesn't work worth a shit, however the Vector kits works with no problems. The only thing the Vapor kit has versus the Vector is there is no Tachometer and yeah you aren't really going to see it. Also the Vector from what I've read will track your distance, 0-60 time, and fuel eco so I'm better off paying $10 more tfor those options I will like.
