Nick Jackson Posted September 21, 2014 Report Share Posted September 21, 2014 I just bought a 99 yamaha banshee last Sunday I took it out this weekend and before I went riding I changed the transmission oil and noticed the oil was milky like there was water in it and my buddy told me I need a head gasket? NEED HELP!!! Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted September 21, 2014 Report Share Posted September 21, 2014 More than likely you need a water pump seal, should change the bearing, impeller, and gear while you are in there. It's not the head gasket. 1 Quote Link to comment Share on other sites More sharing options...
91coupemike Posted September 21, 2014 Report Share Posted September 21, 2014 Head gasket will not effect your transmission oil. That being said, pull the cover off of the clutch side and replace all the plastic junk and seals while you are there. Drive gear is about $45 for the billet one, and the water pump impeller needs to be upgrades too. The stock oem stuff is doodoobutter Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted September 21, 2014 Report Share Posted September 21, 2014 Head gasket will not effect your transmission oil. That being said, pull the cover off of the clutch side and replace all the plastic junk and seals while you are there. Drive gear is about $45 for the billet one, and the water pump impeller needs to be upgrades too. The stock oem stuff is doodoobutter not to pick a fight, I'll take a oem impeller over a billet. I've seen 2 pro designs wear and walk all over tearing its self to pieces. Quote Link to comment Share on other sites More sharing options...
91coupemike Posted September 21, 2014 Report Share Posted September 21, 2014 (edited) well i just replaced mine with a vitos impeller. lol dont say that! thats weird they walked and wore, seems like something else would have to been to blame, unless poor build quality. Edited September 21, 2014 by 91coupemike Quote Link to comment Share on other sites More sharing options...
Nick Jackson Posted September 21, 2014 Author Report Share Posted September 21, 2014 Head gasket will not effect your transmission oil. That being said, pull the cover off of the clutch side and replace all the plastic junk and seals while you are there. Drive gear is about $45 for the billet one, and the water pump impeller needs to be upgrades too. The stock oem stuff is doodoobutter are you talking "plastics" as in my gaskets? Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted September 21, 2014 Report Share Posted September 21, 2014 well i just replaced mine with a vitos impeller. lol dont say that! thats weird they walked and wore, seems like something else would have to been to blame, unless poor build quality. The shaft wears where it sits on the seal. Known problem. Mull supposedly has a billet one with a hardened shaft to stop this from happening Quote Link to comment Share on other sites More sharing options...
91coupemike Posted September 21, 2014 Report Share Posted September 21, 2014 (edited) are you talking "plastics" as in my gaskets? no, the oem water pump and water pump drive gear are plastic, and my impeller was cracked, and the drive gear was melted or something, was about to break when i took it apart. the clutch cover has the water pump built into it, in front of it with the kidney bean shaped plastic cover is your water pump cover, it may be leaking on the inside of the clutch cover getting water into your oil. Edited September 21, 2014 by 91coupemike Quote Link to comment Share on other sites More sharing options...
91coupemike Posted September 21, 2014 Report Share Posted September 21, 2014 The shaft wears where it sits on the seal. Known problem. Mull supposedly has a billet one with a hardened shaft to stop this from happening ah i got my drive gear from mull, if the vito takes a dump i know where to get the next one, Quote Link to comment Share on other sites More sharing options...
sheerider11 Posted September 21, 2014 Report Share Posted September 21, 2014 Also check the oring on the 45° elbow through the case. Quote Link to comment Share on other sites More sharing options...
hoppedupandcutdown Posted September 21, 2014 Report Share Posted September 21, 2014 The cover gasket has to be bad around the tube also for the leaking o-ring the let coolant into the trans, just the o-ring and it will run thru the center of the case and to the floor. I also prefer stock stuff. Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted September 22, 2014 Report Share Posted September 22, 2014 More than likely you need a water pump seal, should change the bearing, impeller, and gear while you are in there. It's not the head gasket. 100% this! You should quit taking advice from whoever told ya it's the head gasket. Crank case and gearbox on two strokes are totally seperate. Quote Link to comment Share on other sites More sharing options...
