Jarod Andrew Curtis Posted September 17, 2014 Report Share Posted September 17, 2014 I bought a 2003 banshee here in Germany it has all the mods to be street legal and I have never owned a banshee/ atv in my life. So I'm learning as I go and as of right now I have come to find that it's missing bolts and has plenty of stripped ones on it I just bought a new +2 a arm set with new Elka stage one front shocks and just put those on recently. Where can I find a new bolt set for the banshee and how should I go about getting the stripped screws off. Also I want to get an American star swing arm what axle should I get with that and what all will I need to have a complete back end as I swing arm axle bearings sprocket hub etc. Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted September 17, 2014 Report Share Posted September 17, 2014 RPM, Lone Star, Dura Blue all have some of the higher priced but nicer axles. You can save a little coin with G-force or Tusk axles. You get what you pay for. Same applies to your swing arm choice. As far as the stainless bolt kits, the one posted is pretty decent. Most kits are about the same. Just make sure you understand what is/isn't included. Steer clear of using them for suspension pivot points and use anti seize when installing them the first time. Quote Link to comment Share on other sites More sharing options...
Jarod Andrew Curtis Posted September 17, 2014 Author Report Share Posted September 17, 2014 Thanks is there any other place to get that other than ebay Quote Link to comment Share on other sites More sharing options...
Jarod Andrew Curtis Posted September 17, 2014 Author Report Share Posted September 17, 2014 Ok and what should I use to get super stripped screws out I am trying to get off my chain guard Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted September 17, 2014 Report Share Posted September 17, 2014 You could cut a slot in them with dremal and cut-off wheel and use straight slot screw driver. Small cold chisel. Worse case grind head off comepletly and use vice grips after removing cover. Quote Link to comment Share on other sites More sharing options...
Starwriter Posted September 18, 2014 Report Share Posted September 18, 2014 Support the BHQ sponsors. This is the bolt kit supplier recommended around here. http://alloyboltz.com/catalog/index.php Quote Link to comment Share on other sites More sharing options...
