draggins10 Posted September 17, 2014 Report Posted September 17, 2014 Hey, I'm changing out my stock carbs for a set of Mikuni TM series flat side 28mm carbs. Can I use my old jetting? Quote
draggins10 Posted September 17, 2014 Author Report Posted September 17, 2014 If not what do you guys suggest. Mods are fmf fatty pipes, pro design filter w/o lid, 4mil crank w/ spacer plate, +4 timing Quote
draggins10 Posted September 17, 2014 Author Report Posted September 17, 2014 Wanna put these on today. Any suggestions? Quote
Infamous039 Posted September 17, 2014 Report Posted September 17, 2014 Probably going to have to reject them to be safe. Bogator215 Quote
draggins10 Posted September 17, 2014 Author Report Posted September 17, 2014 What would you suggest to try out. They came with 30 pilot and 280 main Quote
trickedcarbine Posted September 18, 2014 Report Posted September 18, 2014 Start 300 maybe 320 to be safe on the main. Needle second from richest clip. Definitely 30 pilot. Quote
draggins10 Posted September 18, 2014 Author Report Posted September 18, 2014 Start 300 maybe 320 to be safe on the main. Needle second from richest clip. Definitely 30 pilot.Needle second from richest clip, Is that second from the bottom of the needle? Like this? Quote
