banshee den Posted September 16, 2014 Report Share Posted September 16, 2014 I pulled my carbs apart to change main jet cause it sloppy on low rpms but hauls on high rpms as of now the main is 160 . I'm at 1100Ft above sea level (might be 1000 or 1200) I got T5 pipes 35 pwk carbs with DEK needles on top clip. boysen reeds (for now) bored .50 over K&N filter (no air box lid) what mains do you suggest to try 155 152 or 150? Quote Link to comment Share on other sites More sharing options...
special06shee Posted September 16, 2014 Report Share Posted September 16, 2014 What make you think its your mains? You said it rips up top but "sloppy" down low. Id look into pilots or that needle might be too rich. Most likely needle. Try cel. Quote Link to comment Share on other sites More sharing options...
banshee den Posted September 16, 2014 Author Report Share Posted September 16, 2014 what would the cel needles do? Quote Link to comment Share on other sites More sharing options...
special06shee Posted September 16, 2014 Report Share Posted September 16, 2014 http://www.carbparts.com/keihin/needles_tuning/pj.htm They can do whatever ya need them to do. Study up^^ Quote Link to comment Share on other sites More sharing options...
banshee den Posted September 16, 2014 Author Report Share Posted September 16, 2014 thanks Quote Link to comment Share on other sites More sharing options...
special06shee Posted September 16, 2014 Report Share Posted September 16, 2014 Yup. Most guys have great luck with the cel needle. Ive ran them in the past too with good results. Quote Link to comment Share on other sites More sharing options...
banshee den Posted September 16, 2014 Author Report Share Posted September 16, 2014 hope I have good luck with them. Quote Link to comment Share on other sites More sharing options...
cyclewizzard Posted September 17, 2014 Report Share Posted September 17, 2014 I am at 1100 ft 35 pwk 48 pilots 155 main cel needle middle position on 91 octane if that helps Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
