camatv Posted September 18, 2014 Report Share Posted September 18, 2014 i have had all kinds of problems with intake gaskets.. i now just run ultra grey ( says right on the package solvent, chemical gas resistant. ) for years and years. only about 7 bucks a tube. and easier to clean than the 1211 crap no gaskets at all seal it up slap it together and ride. just dont go overboard and use 1/2 a tube a side. it takes just a nice thin coat just like cases. Quote Link to comment Share on other sites More sharing options...
sprinklerman Posted September 18, 2014 Report Share Posted September 18, 2014 I 1211 all my gaskets... last thing I want to do is start stripping shit down because of a leaking gasket... 1211 everything and dont look back with a passing leak down test...and yet it STILL blows. What's the dealio? Quote Link to comment Share on other sites More sharing options...
sprinklerman Posted September 18, 2014 Report Share Posted September 18, 2014 Wish I knew... wasnt from an air leak though thats for sure..One variable eliminated at least. Quote Link to comment Share on other sites More sharing options...
registered user Posted September 18, 2014 Report Share Posted September 18, 2014 i have had all kinds of problems with intake gaskets.. thats weird. im 99% sure the '03 i just took the cages out of had original oem gaskets. 11yrs old aint bad. probly could reuse em but for a couple bucks it aint worth it. give em a try sometime Quote Link to comment Share on other sites More sharing options...
91coupemike Posted September 19, 2014 Report Share Posted September 19, 2014 Vito's gaskets on my build did nothing but leak. Nothing like having to pull the top end back apart to pass a leak down test. I used ultra grey as that's all I had, copper spray would have been choice! I'll go through a few heat cycles and see if they leak. Quote Link to comment Share on other sites More sharing options...
registered user Posted September 19, 2014 Report Share Posted September 19, 2014 well sometimes sealer wont help because the leak is through the gasket material. thats why its important to use high qaulity gaskets. i dont have alot of experience with the yamaha gaskets yet but from working on honda and ktm the oem stuff is typically the way to go. with aftermarket brands you never know what your going to get sometimes. now some engines may require special thickness gaskets or special shapes and what not but in those situations i recomend using something like klingersil. its about the best material on the market. ive done a few engines where i needed to lift the cylinder for various reasons with thicker gaskets and i always use klingersil because it hasnt failed me yet. ive even stacked the shit under cylinders and never a problem. 4300 is mostly what i use but theres alot of other materials http://thermosealinc.com/index.cfm/m/4/s/3/ss/33.cfm Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted September 19, 2014 Report Share Posted September 19, 2014 Problem is, in the banshee community it seems that for every one good product there are 10 knock offs. Even knock offs that claim to be OEM. I have found that the VForce gaskets are top notch and they are about the only ones I don't put sealer on. Quote Link to comment Share on other sites More sharing options...
