SOUTHTHIRTY Posted September 15, 2014 Report Share Posted September 15, 2014 Used is used.. run it... you going to bend it anyway. . Quote Link to comment Share on other sites More sharing options...
dave5.0 Posted September 15, 2014 Report Share Posted September 15, 2014 So is this .030 at the end of the axle out by the threads for the end but? Quote Link to comment Share on other sites More sharing options...
Factory350 Posted September 15, 2014 Report Share Posted September 15, 2014 Two months later....I understand both sides of this which are apparent but .030" Probably isn't going to be noticed by eye when pulling a part to sell it. Buying used part usually results in receiving used parts. You obviously received it, visually inspected it and it obviously looked good to you prior to measuring it. 2 months after the fact I don't believe needs to result in a "bad seller" section. He seemed to be respectful in his response and answered you back. If it's in fact a lsr, contact them and they will straighten it under warranty and you're good to go! 1 Quote Link to comment Share on other sites More sharing options...
sheerider1026 Posted September 15, 2014 Report Share Posted September 15, 2014 Remind me to never sell this guy shit 2 Quote Link to comment Share on other sites More sharing options...
sprinklerman Posted September 15, 2014 Report Share Posted September 15, 2014 If .030" is going to cause "premature bearing wear" I'd hate to see what out of round tires might do to a carrier. Also, you didn't check the axle in V Blocks. That's the only accurate way to do it. Why be so worried about .030" , but then not check it accurately? Your carrier bearings, even if brand new, could allow that much movement. Edit: for the record, I wouldn't want a bent axle either, I sympathize for you in that regard. But if I buy a used part that passes visual inspection, that's all I expect of a seller. (Example: crankshaft looks, sounds good, but ends up out of true) Quote Link to comment Share on other sites More sharing options...
SOUTHTHIRTY Posted September 15, 2014 Report Share Posted September 15, 2014 Put your wheels and tires on.... dial the knobby in.....lol... do u shave your tires every ride to get them to dead 0? Quote Link to comment Share on other sites More sharing options...
LCW Posted September 15, 2014 Author Report Share Posted September 15, 2014 Wow, you people seriously amaze the hell out of me. If it were any of you, you would be raising hell about it too. Deal is that it was said to be straight and it's not. Pretty sure lsr only warranties it to the original buyer. Talk all the shit you want, I still have the packaging it came on from him. It never left the bench until a couple days ago. Quote Link to comment Share on other sites More sharing options...
sprinklerman Posted September 15, 2014 Report Share Posted September 15, 2014 Do you seriously expect every person who sells an axle or crank to own a set of V blocks and indicators? Because other than that, it'll be mighty hard to spot .030" runout unless you noted it while riding. ..which I doubt you would.. Quote Link to comment Share on other sites More sharing options...
#1JUANstunna Posted September 15, 2014 Report Share Posted September 15, 2014 Someone buy the damn axle off of this guy and run it. Quote Link to comment Share on other sites More sharing options...
Sandking Posted September 15, 2014 Report Share Posted September 15, 2014 Abe can you return the axle under warranty? If so that would fix this. Quote Link to comment Share on other sites More sharing options...
sprinklerman Posted September 15, 2014 Report Share Posted September 15, 2014 Abe can you return the axle under warranty? If so that would fix this.Why should he? He'll have 50.00 in shipping on a 115.00 axle. Quote Link to comment Share on other sites More sharing options...
LCW Posted September 15, 2014 Author Report Share Posted September 15, 2014 I expect to get a part that is as described by the seller whether it is new or used. Two months later or not, it didn't get bent this bad in shipping and it sure as hell didn't get bent on the bench. I see that the thread has been moved. This site is nothing but politics. This situation would be totally different if I sold the axle to Abe. Quote Link to comment Share on other sites More sharing options...
Sandking Posted September 15, 2014 Report Share Posted September 15, 2014 Ill buy it for 165 shipped then if replaced Quote Link to comment Share on other sites More sharing options...
Deadbeat Posted September 15, 2014 Report Share Posted September 15, 2014 two pieces of wood and big fucking hammer Quote Link to comment Share on other sites More sharing options...
n2otoofast4u Posted September 15, 2014 Report Share Posted September 15, 2014 FFS Quote Link to comment Share on other sites More sharing options...
