h8honda Posted November 19, 2003 Report Share Posted November 19, 2003 i have a 2002 shee and im wanting to put a longer swing are on it. Is there any body that can give me some input on what i should get im thinking 4in. Ihave been looking on ebay and found some but not sure bout them my shee is my baby but also on a tight budget. any info is great, and thanks Quote Link to comment Share on other sites More sharing options...
2001SSTBanshee Posted November 19, 2003 Report Share Posted November 19, 2003 why longer? Quote Link to comment Share on other sites More sharing options...
h8honda Posted November 19, 2003 Author Report Share Posted November 19, 2003 because im setting it up for drag and im wanting info from people who have already done this sort of thing. i think im going to add to a stock one but am also up for input. i have a history of raceing so i dont have probs with keeping the front end down and to help im 5'10" @175lb so not a prob....Just wanting to have some fun plus you haft to admit it makes the shee look fu*king badass. Quote Link to comment Share on other sites More sharing options...
h8honda Posted November 19, 2003 Author Report Share Posted November 19, 2003 o ya and where is a good place to get a timing adjuster......... Quote Link to comment Share on other sites More sharing options...
ledofthezep Posted November 19, 2003 Report Share Posted November 19, 2003 Call me pshyco....but after running my -2 arm in the sand,...if I were to build me a dragger,...I may go with a -2 & a wheelie bar! I pulled the holeshot on every ride I pulled up next to(except the shee's with bottles)...I hooked up great & as long as my nuts were up by the tank the front end would stay down just fine. Maybe I am nuts... Quote Link to comment Share on other sites More sharing options...
Cotton eyed Joe Posted November 19, 2003 Report Share Posted November 19, 2003 Call me pshyco....but after running my -2 arm in the sand,...if I were to build me a dragger,...I may go with a -2 & a wheelie bar! I pulled the holeshot on every ride I pulled up next to(except the shee's with bottles)...I hooked up great & as long as my nuts were up by the tank the front end would stay down just fine. Maybe I am nuts... Thats the best way to do it. BUT if you don't want to run a wheelie bar you either have to extend the front end to get the unsprung weight up to keep you upright, or extend the swingarm. When you extend the swingarm, you change the CG of your banshee, pushing the CG forward, which reduces the amount of weight on the back tires, unless you can loft the front end some, which is harder since you just moved the CG forward. If you extend your swingarm for dune/drag I would go +4 since if you go +6 it can cause some headaches with the chain. You have to run the chain loose enough so that when you jump, it can tighten without breaking or ruining your sprockets or bearings, but it has to be tight enough that it doesn't fall off when you aren't jumping. My recommendation is +4 for Dune/Drag, and +6 and above for Drag Only. If you run a wheelie bar, -2. Quote Link to comment Share on other sites More sharing options...
ledofthezep Posted November 19, 2003 Report Share Posted November 19, 2003 Right on Cotton,...summed it up pretty good. If I wind up doing that sometime down the road...would probably go with 300ex shocks up front or something like that...to lower the front a bit like ya said. Good post man... Quote Link to comment Share on other sites More sharing options...
h8honda Posted November 20, 2003 Author Report Share Posted November 20, 2003 well thanks for your guys information seams like i have alot of thinking to do hopefully i will be able to post some pics of my shee soon thanks Quote Link to comment Share on other sites More sharing options...
MULLET~BOY Posted November 20, 2003 Report Share Posted November 20, 2003 i'm not got read evry thing becouse i'm lasy lol but i wouldn't recomend buying a swing arm off ebay i bought one from a guy who sells them and it was weled crooked and my chain flew off and cracked my case i would save and get a decent made one Quote Link to comment Share on other sites More sharing options...
h8honda Posted November 21, 2003 Author Report Share Posted November 21, 2003 o sorry bout you prob but i will buy stock and the add to that my self. I would not trust anyones elses work no efence to anybody especially when it is my shee we are talking about...... Quote Link to comment Share on other sites More sharing options...
