Clutch cover
Power_Man
Here is a link I have had saved. I did the same on one of my motors many years ago. It took a few tries to get a stiff enough plexi that was stiff enough to seal up with just three screws. Masked of a circle just inside of the screws and sprayed the outside 3/8"ish ring the color of the clutch cover. Then I used that Annodize rattle can paint to put a translucent blue over the inner circle. Cleared it with gloss enamel. Actually lasted quite a while.
http://www.thequadconnection.com/walkthroughs/banshee-see-thru-clutch-cover-mod/
I had done a google search after I posted this and came across that thread.
I don't want to go that extreme. Currently I have a billet round cover on it that has a gasket. I wondered why the stock and aftermarket ones has gasket or were even there to begin with seeing it is sealed behind it.
I just want to drill a 5/8 hole or what ever size is needed to get a socket on that nut.
So I guess if you can cut a big hole, a small one will be no big deal. :)
