Ported Reed Cages
8HONDO
  • Replies 30
  • Created
  • Last Reply
Top Posters In This Topic
There's some on B370's Page , that's what I went by to port mine (his pics came out alot better than the ones I took of mine afterwards).
what tools are needed for this? I have a dremel and sand paper. Im thinking about trying to do something like this but I need more info on how the reed cages work so I can understnad what Im trying to acomplish.
Yeah, I used a dremel with an orange (I think it's aluminum oxide) bell-shaped bit, a rattail file and a small thread file (triangular shaped). What you want is to smooth everything out on the inside, NOT f*ck with the rubberized stuff on the outside where the reeds close against. You want to leave at least 1/16" of area for the reed to contact.
If you look at the stock cages, the casting itself has some sharp edges, and the black rubberized stuff extends into the inside. You want to take off the rubber (inside only), smooth all the castings out (don't polish it, you want a somewhat rough surface, don't use finer than 80 grit anything), and remove some material where the reeds shut (again, make sure there's at least 1/16" for the reeds to close against all the way around their edge). Don't knife edge the little arms either, make 'em round.
As long as you don't take off too much around the reed seats or otherwise mess up the rubberized part where they shut, you should be fine. BTW I went one clip leaner on the needles after I did mine, and will be starting on my RZ cages pretty soon, if you need some pics lemme know.
thanks for all the info I may give this a shot, How would rooky porting on them liek I would probably end up with, compare to Deltra V-Force 2's?
I dunno for sure, but I know the price of porting them yourself vs. the Delta's worked for me. I think Scott M & Banchetta did some testing awhile back and the Delta's did better on the dyno (anyone else remember the specifics?). If you got the bucks go for the Delta's, not many people didn't like them, if not port the stockers and get some free hp.
NICE job Justintoxicated, looks great (might want to see if you can blend that one spot in the top left opening where the dremel cut a little deep). Take off the rubber in those corners: I used a small thread file (triangular cross-section) and it worked great, those can be a sharp corner. Excellent work though, how long did it take ya?
I only dynoed the stock cages vs. the ported cages. No gain, but no loss either....It didn't make any differences w/ the ported carbs either......I didn't dyno any Deltas, but wish I had some to dyno......maybe ported motors will have more results..
I blended it the best I could that was my biggest mistake :( Never done this before though...Let me get some pictures of the finished cages.
I spent about 5 hours including removing them from the bike
I was digging around in my little black book and found Factory Yamaha Roadrace specs on RZ reed cages. Widen openings 1.5mm, Raise openings 4.5 mm and lower openings 4.5mm. All cuts should be at 16 degrees and corners should be at 5 mm radiuses...just a tid bit if your interested...Jim
