4strokebully Posted September 11, 2014 Report Share Posted September 11, 2014 Wat up guys I recently got my rear master and caliper chrome and rebuilt both of them after chroming and it happened to me twice that my rear caliper heated up and locked up once I take the brake line off it unlocks need help please!!! Cleaned fluid and took both apart twice Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
imbill Posted September 11, 2014 Report Share Posted September 11, 2014 The rubber brake line may be bad lettin the fluid go to the caliper but not return !!!!!! Quote Link to comment Share on other sites More sharing options...
Tedder Posted September 11, 2014 Report Share Posted September 11, 2014 Yup, I think imbill nailed it. Not real common but I've seen high pressure hoses cause that exact problem in the automotive field. Quote Link to comment Share on other sites More sharing options...
wfobasheeboy Posted September 11, 2014 Report Share Posted September 11, 2014 Also check Pedal Adjustment. If there no free play it will do the same thing. I have that happen before. just my .02. Quote Link to comment Share on other sites More sharing options...
4strokebully Posted September 11, 2014 Author Report Share Posted September 11, 2014 Thanks guys it's a brand new steel braided line but I'm a check adjustment since I did take it apart Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Piediddy Posted September 11, 2014 Report Share Posted September 11, 2014 Check the 2 axle nuts and make sure they tight. Mine was locking up and would do the same thing. I rebuilt the caliper and rode again till it locked up and bent the brake disc. Then I realized the nuts were loose. Quote Link to comment Share on other sites More sharing options...
Starwriter Posted September 12, 2014 Report Share Posted September 12, 2014 As mentioned, check the adjustment. If the brake lever is hitting the clutch cover and not allowing the master cylinder to completely release, the brake will lock up as the brake fluid heats up and expands. It's also possible that there's chrome in the bore of the master, preventing the piston from completely releasing. Quote Link to comment Share on other sites More sharing options...
